New Construction Ready For Roofing... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-03-2007, 01:49 AM   #1
MLO
New construction ready for roofing...
My roof is sheathed and ready for rooofing. Do I have the plumber come out and give me locations for vents etc., so I can flash them properly during the roofing install?
I'm an owner/builder trying to get dried in. I am probably two weeks away from being ready for my framing inspection. So nedless to say plumbing work really cannot begin until after that, right?
MLO is offline   Reply With Quote
Old 11-03-2007, 02:37 AM   #2
Pipes through the roof would be better, but if you can't, then you can always cut the hole later.
It is a lot trickier if you have never done that before though and will be highly likely to leak if you do not do it right.
Ed
Ed the Roofer is offline   Reply With Quote
Old 11-03-2007, 03:46 AM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
invest in a flat bar and do it later,a good plumber will also do it
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 02:47 PM
New Job in construction Punk8oy81 Carpentry 4 01-28-2007 07:15 PM
Construction Nightmare - need help!! naper_home Building & Construction 5 04-06-2006 04:57 PM
Construction safety nightmare 'Andyman Off Topic 2 09-13-2005 12:20 PM
