New Bulge Under Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-20-2010, 08:25 AM   #16
Residential Roofer
Slyfox's Avatar
(GBR in WA, I presumed there was a leak at the missing cricket or upper corner flashing)
Thanx, I thought I missed something.
I have never seen framers coat the cut ends of OSB either, it's a shame to because OSB is both cost effective and more environmentally friendly than using plywood.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 12-21-2010, 02:26 AM   #17
Rewards Points: 526
Originally Posted by OldNBroken View Post
Yeah, I'm thinking your problem may be originating from that chimney also. It's not the sheet bowing in the middle, it's the joints racking.
Seems like an awfully old roof to have two layers AND osb under it. Then again, you do live on the rusty side of the state.
THat thought crossed my mind too - we have had a lot of wind with rain over the last few weeks and that might have been enough to propel moisture under the chimney flashing. Not sure how old the roof is, but I do think it is not as old as it looks.
I am glad to get all the input - thanks to everyone for that. I am going to keep my eye on it and I hopefully get to the bottom of it in the spring.
Windows is offline   Reply With Quote
Old 12-21-2010, 01:05 PM   #18
HomeAdditionPlus.com
Rewards Points: 29
That chimney roof flashing looks in rough shape. I bet you have water getting in under the shingles due to a roof leak around the chimney flashing area. A driving windswept rain could easily push water up underneath that flashing.
As others are saying I believe the joints are racking. I also believe plywood is the better choice on a roof.
mjdonovan is offline   Reply With Quote
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 01:03 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 06:29 PM
Painting New Roof Shingles to match old ones? Lgarced Painting 0 03-25-2010 08:46 PM
Weight vs. durability of architectural shingles JoeT Roofing/Siding 10 06-29-2009 06:50 AM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 03:42 PM
