New Bulge Under Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-17-2010, 09:17 PM   #1
Rewards Points: 526
I was up on the roof today for the first time since winter has begun and I noticed a strange bulge that was not there a couple of months ago. It's about 2 1/2 feet long, a foot wide and rises a couple of inches. The whole area feels solid. The roof is two layers of 3 tab asphalt shingles over an OSB deck. The attached picture is as clear as I could make it. I will be re-doing the roof in the spring, but before then I am wondering what the hell is going on. Anyone know? Thanks.
(the bulge stretches across the middle of the pic)
Windows is offline   Reply With Quote
Old 12-18-2010, 02:03 AM   #2
starkenwolf's Avatar
Could be the tar paper rolled up at a seam.....water penetrated and froze, causing it to heave. Melted away in the thaw and left you with a nice "lump". You'd be surprised at how sturdy rolled tar paper can feel.
Good luck!
starkenwolf is offline   Reply With Quote
Old 12-18-2010, 09:31 AM   #3
Doing This Way Too Long
Rewards Points: 532
It's your OSB racking at the joints.
OldNBroken is offline   Reply With Quote
Old 12-18-2010, 09:47 AM   #4
could be some water has been getting in around that chimney flashing..?
1910NE is offline   Reply With Quote
Old 12-18-2010, 11:01 AM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 180
Whatever sheeting you replace, use plywood, not OSB.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-18-2010, 12:10 PM   #6
MJW
Why Rusty?
MJW is offline   Reply With Quote
Old 12-18-2010, 02:20 PM   #7
Rewards Points: 180
Because beaver barf (OSB) falls apart when wet. It's not as bad as partical board but still should not be used.
Old 12-18-2010, 08:22 PM   #8
Rewards Points: 526
Thanks for the input. I imagine I should plan on replacing all the OSB? This roof project is getting better and better.
Old 12-18-2010, 09:39 PM   #9
Rewards Points: 532
OSB is used all the time as an underlayment with no problems. Yours is not a material issue. Install anything too tight and when it expands it's going to buckle like that. This is why they tell you right on the product to leave an 1/8" gap
The Following 2 Users Say Thank You to OldNBroken For This Useful Post:
MJW (12-19-2010), Windows (12-19-2010)
Old 12-18-2010, 10:24 PM   #10
Roofing & Renovation
SoarRoofing's Avatar
I agree OSB is used all over the country for roof decking it is my opinion that it is missing an "H" clip and now starting to buckle I would leave it alone (provided it does not get any worse) since you are going to replace the roof in the spring. and once the shingles are off it will be an easy fix.
Good Luck
SoarRoofing is offline   Reply With Quote
The Following User Says Thank You to SoarRoofing For This Useful Post:
Old 12-19-2010, 12:01 AM   #11
Registered User
Rewards Points: 526
It appears the leak is above and closer to the chimney flashing, hence the second ripple there.
Osb is inferior to plywood mostly in it's drying ability after wet. Not recommended for walls in your City: http://www.google.com/url?sa=t&sourc...JSz4eA&cad=rja
Or around a Coastal area: http://www.coastalcontractor.net/cgi...ticle.pl?id=14
It will probably hold that shape: http://alcor.concordia.ca/~raojw/crd...say000292.html
As said, the gap is not there, installed tight without an "H"- clip: http://www.buildingscience.com/docum...d%20in%20walls
Sorry to depress you further...... http://www.ewpa.com/Archive/2006/aug/Paper_266.pdf
Gary, South about 35 miles
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 12-19-2010, 06:23 AM   #12
Residential Roofer
Slyfox's Avatar
It will probably hold that shape: http://alcor.concordia.ca/~raojw/crd/essay/essay000292.html
I reread to OP and he doesn't mention a leak, am I missing something?
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 12-19-2010, 08:51 AM   #13
MJW
OSB does not bow like that. It swells if anything when it gets wet. Plywood bows just laying flat on the ground. Although any board will bow without the proper spacing.
GBR, that first link is for walls that have no vapor barrier, not vented roofs.
I'll use OSB every time over plywood.
I haven't seen a pic of the OSB board from the OP yet.
Here's a good link http://bct.eco.umass.edu/publication...d-and-plywood/
Old 12-19-2010, 11:36 AM   #14
Rewards Points: 532
Yeah, I'm thinking your problem may be originating from that chimney also. It's not the sheet bowing in the middle, it's the joints racking.
Seems like an awfully old roof to have two layers AND osb under it. Then again, you do live on the rusty side of the state.
Old 12-19-2010, 06:56 PM   #15
Registered User
Rewards Points: 526
I presumed there was a leak at the missing cricket or upper corner flashing, not the first time I would be wrong..... I've had OSB bow the 10' edge studs right out/off the wall, with a gap installed, after much rain. Inspectors around here have made the framers cut the gaps at the sheet edges, if left out. Just not my favorite product as it dries out slowly compared to plywood.
MJW, I did state walls for that link, read it again, slowly. Just showing what I think of that smelly (formaldehyde) product after 30 years of installing it professionally on walls and roofs since it came around in the '80's. (No choice)
“Irreversible edge swelling has been the biggest knock on osb. Manufacturers have done a good job of addressing this issue at the manufacturing facility and during transportation by coating panel edges. But the reality is that builders don’t limit osb use to full-sized sheets. The edges of cut sheets are seldom if ever treated in the field. Houses under construction get rained on. And if you use osb in an area of very high humidity, like over an improperly vented attic or over a poorly constructed crawlspace, you are asking for trouble.
Osb responds more slowly to changes in relative humidity and exposure to liquid water. It takes longer for water to soak osb and conversely, once water gets into osb it is very slow to leave. The longer that water remains within osb the more likely it is to rot. Wood species has a significant impact. If osb is made from aspen or poplar, it gets a big fat zero with regard to natural decay resistance. Many of the western woods used to manufacture plywood at least have moderate decay resistance.” From: http://bct.eco.umass.edu/publication...d-and-plywood/
OSB and plywood are about equal except when wet. Plywood (2.7) has almost twice the vapor permeance of OSB (1.5) and 10 times the moisture diffusivity: Chart: http://alcor.concordia.ca/~raojw/crd...say000129.html
We can only guess at the problem until the OP wants to remove the shingles. I would check the chimney carefully. I agree there was no gap but also think water is involved. My 2cents…..
Gary
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 01:03 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 06:29 PM
Painting New Roof Shingles to match old ones? Lgarced Painting 0 03-25-2010 08:46 PM
Weight vs. durability of architectural shingles JoeT Roofing/Siding 10 06-29-2009 06:50 AM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 03:42 PM
