Neighbor Doesn't Allow Use Of Their Side ? What To Do? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-02-2009, 07:34 PM   #1
Neighbor doesn't allow use of their side ? What to do?
We need to repair the roof but my neighbor does not allow us use his side of the house. What can we do?
LUNA22 is offline   Reply With Quote
Old 09-02-2009, 07:43 PM   #2
Is this a duplex?
Why do you need to use "their side" ?
Old 09-02-2009, 08:28 PM   #3
You need to be more explicit please.
Does he not want them to walk on his/her grass?
Are two homes so close together that debris may fall on his property?
etc...
Ed
Ed the Roofer is offline   Reply With Quote
Old 09-03-2009, 10:04 AM   #4
Unhappy
We need to repair the roof AND CHANGE THE SHINGLES but my neighbor does not allow us TO use his side of the house.WE ALLOW HIM TO USE OUR WALL TO PUT HIS GATE. MY HOUSE IS 0NE FT AWAY FROM HIS HOME. What can we do? HELP
Old 09-03-2009, 10:10 AM   #5
RDS
Rewards Points: 150
Use it for WHAT?
RDS is offline   Reply With Quote
Old 09-03-2009, 10:25 AM   #6
Old School
Willie T's Avatar
They are trying to tell you that all the work on a roof can be, and usually is, done from right on top of your roof.
Willie T
Old 09-03-2009, 10:58 AM   #7
As long as the roofers have access from 3 sides they should not need access from the 4th side
Actually only front & back should be needed depending upon what needs to be replaced
Old 09-03-2009, 08:30 PM   #8
Well my roof is like a tringle and is hard to reach.
Old 09-03-2009, 08:33 PM   #9
Well, it is their property
They do have the right to refuse use of it for roofing your house
They may be concerend with possible problems if someone were to fall on their property/or while accessing your roof from their property
Your roofers should be able to work around this
What did they say when you talked to them?
Old 09-03-2009, 08:56 PM   #10
They can not do the roof
Old 09-03-2009, 08:58 PM   #11
Can i istall the new shingles on top of the old ones.
Old 09-03-2009, 08:59 PM   #12
We Don't what to do no more
Old 09-03-2009, 09:01 PM   #13
Find a new roofer who can do it
Better to always tear off the old shingles
Old 09-03-2009, 09:02 PM   #14
Get other bids.
Contact your local building code dept.
Contact your state's attorney.
Demand that he remove his gate.
Old 09-03-2009, 10:45 PM   #15
You have the right of egress to be able to fulfill your building requirements.
Contact someone in the village hall code department and ask your question and they can force him to allow the work temporarily on his property.
I would detach that fence the very next morning too.
Ed
Durock installation in bath, what side goes out? smcmurrey Building & Construction 8 12-12-2010 07:48 PM
Ceiling mounted clothes rod (one side wall mount, one side ceiling mount) DCA General DIY Discussions 9 08-17-2009 11:13 AM
Taping inside corners....one side at a time? yummy mummy Building & Construction 10 07-23-2008 03:23 PM
Side By side refrigerator Susie Q Appliances 6 08-31-2007 04:26 PM
Cathedral ceiling without sofit vent on one side ChrisO Roofing/Siding 3 01-31-2007 11:51 AM
