Need Some Help With Tin Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-18-2009, 10:54 AM   #1
Need some help with tin roof
Hi everyone,
I live in Western Kentucky. And I am planning on putting Tin on my roof..
I have a couple of questions..
First .. I have some used tin and it has cool-seal on it .. the cool-seal is peeling off in places and I want to remove it . What is the best way to remove this off the tin.
Second.. If shingles are laying flat on my roof. can I lay foiled bubble wrap on the roof and just lay the tin or do I need to lay 1by strips then the tin?
Thanks for any and all help
Grizzly Bob
Grizzly Bob is offline   Reply With Quote
Old 01-18-2009, 03:44 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
google cool seal find thier website and ask them what to remove it with.
as far as the bubble wrap goes i never heard of doing that under a metal roof sorry
Tom Struble is offline   Reply With Quote
Old 01-19-2009, 06:34 AM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Remove the shingles and put the roof on the sheathing. Here are some pics of a recent one to help you. http://www.albertsroofing.com/Tin%20...to_gallery.htm
tinner666 is offline   Reply With Quote
Old 01-27-2009, 12:17 AM   #4
I've seen guys go right over top of shingles with tin if the shingles aren't too curled. You may have to use longer fasteners depending on how many layers of shingles there are. We sometimes strap the roof horizontally every 16" with 1x4 and then screw to them. If it were me I'd strip the roof down to the original sheathing like the "tinner" suggested. Then you know what you are up against. But that is alot of work and very weather dependant. Your call...good luck.
the carpenter is offline   Reply With Quote
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 06:37 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
