In Need Of Roofing Contractor in Indianapolis
I disagree. DO NOT give your paper work, not until you've gotten an estimate first. Ask the legitimate licensed and certified roofing contractor what he thinks needs to be done to repair the damage. Ask what it costs to fix. Get it in writing. Then feel free to share insurance paper work.
The problem with showing your paper work first is like playing poker with your cards face up. There are lots of unscrupulous contractors out there that will do what the insurance company is offering, weather it be right or wrong, and it's usually wrong.
Here are some things storm chasers may skip... ventilation upgrades. Many many people don't understand ventilation. Insurance will almost always just apy for replacement, homes usually don't have adquate ventilation to meet code, therefore the insurance should pay. Many storm chasers will use the most god awful cheapest materials on the market. Most insurance companies won't pay to repalce flashings though flashings are an essential part of the roof system.
I tell my customers be prepared to come out of pocket because insurance pays for minimum code and my roofs exceed minimum code. here are some upgrades you can expect from a legitimate roofing contractor. ice shield at the problem areas including valleys and pre-flashings at chimneys, skylights, pipes and where the roofs meet the walls. basically any areas to be flashed with metal IMO should be preflashed with ice shield. It's cheap insurance. felt upgrades, minimum code is 15# felt, I install 303 felt and fiberglass felt. Both will cost double what 15# felt costs. Flashings, I won't replace a roof if I am not replacing the flashings. LOTS of roofers have no problem reusing flashing. Is the flashing good now? maybe, will it be good in 7 years? Probably not? Will it cost more or less now than it will in 7 years to replace the flashings? it'll cost less now to replace the flashings and you will have years and years of trouble free roof. What about ventilation, I mentionmed earlier? Are your kitchen and bath vents in order? What about intake, and exhaust? This all needs to be corrected.
The insurance company won't pay for upgrades, if you plan to hire a roofer who cares, plan to pay out of pocket above and beyond what the insurance company is offering you for the roof. Some roofers can get the insurance company to pay additional, but still they are not responsible to pay above minimum code unless it is pre-existing, which usually is not the case. And if it is the case it must be proved.
-Grumpy
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
