Need Opinions ASAP - Roofer Causes Expensive Problem With Furnace - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-31-2012, 12:33 AM   #1
MB1
Need Opinions ASAP - Roofer causes expensive problem with furnace
Is my roofer incompetent? I am trying to understand what a roofer should be reasonably expected to know about replacing vent caps during a re-roof. Around time of my mobilehome re-roof, my furnace stopped working. The roofer came back to assure me he didn't create blockage and that he has never created a problem with furnaces not working.
1 month later without heat, tons of my time invested, 8 hours of HVAC repairman time, and $400 in parts, the repairman determined the wrong crown/cap was put on on the venting. Here's what it should look like: http://www.mobilehomerepair.com/medi...yne/903656.jpg The top cap allows hot exhaust out (with Carbon Monoxide) and the bottom is the intake in with oxygen. The cap installed was sharing intake with outgas, causing the flame to go out.
-Should a roofer take an "inventory" of all the different types of caps on a home? Just looking at this cap, I would think would make someone wonder if the engineers had something special in mind for it during design!
-Should he be familiar with all the different types and their applications? For example, I noticed that my wate heater also has a very different style vent cap now and is not mobilehome specific like others I see in my neighborhood. The vent caps for bathroom exhaust fans have 360 degree access to intake/outake whereas old ones were for exhaust only, including a damper, insect/pest screen, and pointed only down the sloped roof (which I assume is to minimize the risk of water getting in to this electric device)
-My roofer said he just uses the vent caps the roofing supplier gives him for bathroom fans, water heater, and furnace vents. He has never heard of a furnace needing a special cap to handle intake/outake.
Appreciate your opinions ASAP.
Thank you,
Marcum
MB1 is offline   Reply With Quote
Old 01-31-2012, 12:41 AM   #2
MB1
Correct vent cap/crown that should have been used
Here's a picture of the correct vent cap/crown that should have been installed
Need Opinions ASAP - Roofer causes expensive problem with furnace-903656.jpg
Old 01-31-2012, 07:20 AM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Interesting to say the least. I've always been at the mercy of my supplier when it came to requesting vent caps. We roofers know how to install them, but generally, we go to the HVAC supply warehouse and describe the apparent system that needs a vent and install what they give us.
As a side note, if we deferred to a HVAC gut and say we were roofing a house,a nd he needed to come and install our vents, we'd then have to correct their installation at the roof as often as not.Some jnow how to flash the vent, some don't.
tinner666 is offline   Reply With Quote
Old 01-31-2012, 07:28 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
+1
I have seen about 10X as many instances of HVAC contractors ruining roofs than the other way around.
That is an odd vent and may have easily been missed and especially if whomever was doing the tear off was fast and not paying attention.
Old 01-31-2012, 12:28 PM   #5
RFN-4A-LVN
Roofmaster417's Avatar
Originally Posted by Windows on Wash View Post
+1
Add one for for me.I have had many call backs on new construction after plumbers and Hvac played roofer.
But at any rate a furnace cap should be matched.Carbon monoxide is a serious issue.It does not take skill to pick out a furnace cap true but a standard cap is much different than a regulated one.
Roofmaster417 is offline   Reply With Quote
Old 01-31-2012, 01:31 PM   #6
MB1
Thanks for the feedback. From the research I've done since this problem occurred, I've learned there are many vent cap types for different applications, climates, etc so it seems to me it would make sense to take a look for anything unusual prior to bidding the job (in this case the business owner did the bid) given this comes out of his pocket, but maybe it is just customary to pad the price for the unexpected. In this case, he depended not on the HVAC supplier but his roofing material supplier.
Old 02-01-2012, 11:50 PM   #7
MB1
27 Deaths Due to faulty vent cap...
This is from 1987 and is no longer an issue, but I think makes a good point. Also, even with electrical appliances you are dealing with potential sparks which you do not want to end up venting back into the insulation kicking off a fire.
http://www.cpsc.gov/cpscpub/prerel/prhtml87/87005.html
WASHINGTON, DC -- Roof vent caps on certain HOME or MILLER brand gas-fired furnaces installed in mobile homes are being replaced free of charge by Lear Siegler, Inc., as a precaution against accidental carbon monoxide poisoning.
Old 05-04-2012, 06:18 AM   #8
Early Worm Gets the Bird
I do not mean to be sarcastic
It is really up to the home owner to make sure things of a mechanical nature and such are checked as to what should be dune prior to having some one messing it up I think this is a foe-paw on the contractors part as well on your part because you should do your home work There are times when there is no avoiding a situation because there is no or not enough information
I think to be fair your contractor should cover Ĺ your expenses to be fair
You may not like what I said Thatís ok
Thank you,
Marcum
Snikosnitzo is offline   Reply With Quote
Old 05-05-2012, 08:44 AM   #9
Rewards Points: 83
Generally speaking, common sense should have kicked in when he took the old cap off and saw 2 separate chambers in the pipe, but how much HVAC knowledge is a roofer supposed to have?
Technically it was the roofers actions that caused your furnace to fail. But you also asked a roofer to do an HVAC job. I would say that's about a 50-50 split.
bcdemon is offline   Reply With Quote
Old 06-20-2012, 10:04 PM   #10
you are in a mobile home. Mobile homes require special furnaces that use all combustion air from the outside, even 90+ furnaces are unacceptable according to code. A roofer is just that a roofer not an HVAC guy not to mention a mobile home is a whole different set of combustion standards. I think the truly incompetant one is the HVAC tech who took eight hours to figure this out.
pardonme2711 is offline   Reply With Quote
Furnace drain problem jkennedy99 HVAC 22 12-05-2015 06:44 PM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 09:18 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Lennox Elite Series Furnace Problem steges HVAC 7 11-06-2010 03:49 PM
furnace burner problem brent h HVAC 2 01-11-2010 08:50 PM
