Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 11-04-2012, 09:27 PM   #1
need an opinion on a roof repair
I had a roof done less than a year ago. It started leaking where the roof meets the wall. The roofer came back out to repair and put flashing over the shingles and siding and used roofing cement to seal it. I have attached pictures.
I am not a roofer but it seems to me that this is an incorrect fix. Shouldnt the step flashing prevent water seepage in this area. Also, is it normal to flash across lap siding as in the pictures.
Any comments are appreciated. Not sure what to do next.
need an opinion on a roof repair-img_1377-1-.jpg   need an opinion on a roof repair-img_1375-1-.jpg
emmsvs is offline   Reply With Quote
Old 11-04-2012, 09:45 PM   #2
That sure looks like masonite or some form or chip board siding.
The way it's done on any siding but the type you have is to run the step flashing up under the siding.
With the type siding you have it would just fall apart if someone tryed to remove it.
There was class action law sutes where people could get free replacement side the stuff was so bad.
Anytime I come up againt this problum I try and talk them into letting me replace the siding with vinyl in that area.
Old 11-04-2012, 10:10 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
Boy that looks very sloppy.There are many things you can do other than that mess.
Each individual shingle should have its own piece of step flashing.Once again if step flashing cannot be installed due to the siding then either flash the wall and instal, a piece of trim board covering the step flashing.
Since your siding extends away from the wall with each panel of siding.,use a chalk line measure about 3" 1/2" off the roof deck then cut the siding off,,flash as usual then install a treated/primed/painted 1"x4" for trim.
Also that siding (In my area) can be purchased from Home Depot or Lowes.I am sure 1 panel would have done that side.
The other choice is to have some patients and loosen up the siding and flash as usual then secure the siding back in place.
Not flashing a wall behind the siding should be done when ALL other choices have been eliminated.A flat bar and a bucket of patients goes a long way in that situation.That wall looks like crap and I am not to sure if I would accept that or not.
The way the siding is deteriorated along the wall it might not have been his installation that was leaking but the condition of the wall.If so too bad,,with that nasty goop and smear he just made it his problem.So now he is going to have to rock that baby.He has sole custody of that now.
Roofmaster417 is offline   Reply With Quote
Old 11-04-2012, 10:20 PM   #4
I almost agree 100% with roof but would like to suggest a slightly differant way.
I cut the siding but cut it a little higher then the 3-1/2 suggested. prime and paint the exposed cut. Pry out the siding (easyer said then do with that junk) and slip in a piece of Z moulding, install the step flashing then use 1 X 4 vinyl lumber instead of pressure treated. Main reason is it will never rot and pressure treated does not like to hold paint.
I use Stainless steel trim head screws to attach it. That way 20 years from now you can still get it off.
Old 11-04-2012, 10:28 PM   #5
RFN-4A-LVN
I was just offering a cheaper solution.I really doubt that siding will last another 3 years with the advanced deterioration process going on.New siding is inevitable..
And now when the OP gets new siding he also gets to address that mess his roofer left for him.
Old 11-07-2012, 12:07 AM   #6
I know alittle about alot
JWilliams850's Avatar
call the roofer back and say his "fix" didnt work and he needs to come back and fix it and that smearing tar on the shingles isnt going to solve the problem. if your roof is still under warranty it shouldnt be a problem and if they wont tell them you call another roofer to fix it and then send them the bill.
JWilliams850 is offline   Reply With Quote
Old 11-07-2012, 01:01 AM   #7
Exterior Construction
Windows on Wash's Avatar
In theory...yes.
The issues is whether or not you want that guy (i.e. that did that "repair") working on the home again.
Sometimes you are better suited to cut your losses.
Old 11-07-2012, 08:57 AM   #8
my step dad and i have had many repair calls like this. smearing tar on everything doesnt fix the problem people.
Old 11-07-2012, 09:21 AM   #9
JOATMON
ddawg16's Avatar
^That is the right way.
As I'm typing...the roofing guy is most likely at my house to put on the roof. I'm doing stucco...but similar process as above. On the side where the existing roof is butting up agains the addittion wall, he will install a 1x6 board nailed to the wall. He will flash up to that board.
Then on top of that board will be z flashing....the stucco will have a weep screed that will be nailed about 1" above the top of the board....but on top of the top flange of the z flashing.
Basically, it creates a layered path for the water....nothing can get to the wood.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
rubber roof repair carl sheffield Roofing/Siding 11 09-22-2011 01:26 AM
Flat roof repair Bholt222 Roofing/Siding 2 07-22-2011 12:34 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Repair and Maintence of a Torch down roof. superdairyboy Roofing/Siding 12 03-29-2011 11:24 PM
Winter roof repair - DESPERATE!!! Sarah24 Roofing/Siding 2 02-03-2009 08:22 PM
