Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-22-2009, 03:20 PM   #1
Need new roof?
Hi Guys...
I have to re-roof a flat top roof 1000 sq ft. near the pacific ocean. When i got the house it had some kind of silver painted foam...which is now harden brittle with spider cracks...
A lot of things come up ...that i just been putting it off...now winter is here again...yikes!
I have been ... with putty knive and gualking filling the hair line and wider cracks on a weekly basis...as a .fix.(no inner ceiling leaks yet)
So there is 1. there is the old tar and pea gravel...2. Rubberize membrane of some sort...welded or self stick...that have been considered.
Here's another question...how about aluminum or some kind of metal sheeting??? Or 'composition' roofing material.....simular to what composition shingles use?
The main thought is longevity and and what is most FIRE retardent? As these old houses are build wall to wall next to each other.
So.....what is the material of choice that will last long and is practical or most popular in a coastal foggy city?...
Has anything NEW come out... HOW ABOUT the self sticking membrane which is relatively new...any feed back on how it is holding up? Something that would last more than 5 years is preferable...
Someone said that the old hot mop pea and gravel...was good for 30 years...?
THANKS AGAIN GUYS!!!
Starrider
ps...ok...had this thread in the chat section...so now in the right roofing section...would like to hear from you roofers.
Last edited by starrider; 11-26-2009 at 04:16 PM. Reason: was not getting enough response in chat section
starrider is offline   Reply With Quote
Old 11-22-2009, 03:58 PM   #2
Remodeling Contractor
Need new roof?
I would recommend you completely remove the old roof material and check that the old sheathing is in good shape. Note any puddling so it can be corrected if needed. Then recoat with TPO membrane.
Old 11-22-2009, 04:51 PM   #3
Need new roof?
Thanks for your reply Bob...!
Old 11-22-2009, 07:29 PM   #4
Need new roof?
post in the roofing section and hope ED THE ROOFER sees it. His posts have helped me alot
What have I done is offline   Reply With Quote
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
