Need Hex Bolt For Older Velux Skylight - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-26-2010, 02:19 PM   #1
Need Hex Bolt for Older Velux Skylight
I have an older Velux skylight purchased in about 1992. Just like most skylights I've seen, the handle is held on to a hex "bolt" which is turned to open/close the window. This hex "bolt" has worn down and needs to be replaced. Unfortunately, Velux has changed styles of hex bolts. The old style, which I need, is held into the operating mechanisim by a retaining screw right through the center of the bolt. The newer ones are snap in and not campatible without replacing the entire operating arm. I have the part number of the old style bolt (017505) however they are not available from Velux nor can I find anything online. The newer hex bolt (017690) is not compatible.
Does anyone have any suggesions as to a source for this bolt? Replacing the operating arm calls for $60 in parts and I'd rather just buy the $8 bolt.
xquercus is offline   Reply With Quote
Specialty bolt - Lag bolt with attached coupling nut? 5thumbs Building & Construction 6 08-22-2011 02:08 PM
Cracked Skylight rjordan392 Kitchen & Bath Remodeling 10 05-22-2010 03:30 PM
Velux skylight install with 10 degree slope and corrugated tin roofing oliverbutthead Roofing/Siding 8 07-06-2008 10:23 PM
New vented skylight in existing roof lightninrodman Remodeling 1 07-26-2007 07:47 AM
Attach a bolt to drywall hdayanan Building & Construction 1 03-17-2006 08:01 AM
