Need Help With Ridge Vent On Unusual Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-24-2010, 04:30 PM   #1
Need Help with Ridge Vent on Unusual Roof
I have finished framing a building that has an unusual roof and I need some ideas on how to apply a ridge vent. The roof is a gable with a shed dormer. The shed dormer ties in at the ridge allowing 2 different angles at the ridge. The roof pitch on the front of the gable is extremely steep 19/12 (58˚) and the roof pitch on the back of the gable (Shed Dormer) is about a 7/12(31˚). I have sent emails to some plastic ridge vent manufacturers (ex. ShingleVent II) and they claim their vents will go to 16/12; any higher and it will leak. Gable venting is not an option on this building. The roof will also be covered in Architectural Asphalt Shingles.
I am looking for some ideas do you have any?
MSBOY is offline   Reply With Quote
Old 03-24-2010, 09:46 PM   #2
firehawkmph's Avatar
Rewards Points: 1,922
Ms,
If the manufacturer is telling you their plastic vent will fit over a 16/12 pitch, I think it would probably work in your situation. You are a bit steeper on one side, but not as steep on the other. When you average the two together, it seems like it should work. The only other thought that comes to mind is the cobra ridge vent that comes in rolls.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Remove Pipe Vent from Asphalt Shingle Roof WaldenL Roofing/Siding 5 09-26-2009 01:46 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 01:17 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Useless Ridge Vent? itwerx2 Roofing/Siding 22 10-22-2007 09:57 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
