Need Help Removing Tar From Bricks - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-30-2009, 09:22 PM   #1
Need help removing tar from bricks
First post here so please be gentle.
In the process of buying a house and the chimney has what appears to be tar on it. Is it possible to clean this off without discoloring the brick?
I've attached a photo that shows this.
Wumpus is offline   Reply With Quote
Old 09-01-2009, 07:47 PM   #2
Commercial Roofing
AaronB's Avatar
Pressure washing?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 09-01-2009, 08:47 PM   #3
10 % sulphiric acid and 90 % water, along with a heavy duty bristled brush and eye and clothing and skin protection and a safe ladder to work from unless you can reach from the roof or top of the crown.
Ed
Ed the Roofer is offline   Reply With Quote
Old 09-02-2009, 09:45 AM   #4
PoleCat's Avatar
Rewards Points: 1,638
Kerosene will disolve the tar enough that is can then be removed with a stong detergent and water.
PoleCat is offline   Reply With Quote
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 04:41 PM
Paver Sand and Blue/Grey Colored Bricks Curious123 General DIY Discussions 4 08-13-2009 09:22 PM
Problem with bricks in fireplace box pulling away from interior wall proofer Building & Construction 1 06-15-2008 08:54 AM
Removing Paint from Bricks ? Piney Painting 7 11-16-2006 02:17 AM
