Need Help Laying Out A Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-17-2011, 08:44 AM   #1
Lost..
Rewards Points: 336
Need help laying out a roof
I am building a small shop with a roof of about 2.8 squares.
The roof deck is 18' wide and about 8' tall on each side of the gable.
I have my starter roll shingle applied all the way around, and I can't decide where I need to start the shingles.
The way it sits now, at 18', six shingles will fit across the bottom perfectly. The next row up (or course) will have to shift 6" to the right or left right? If I do this it puts one of the slits in the shingle right on the edge of the roof on both ends of that course..Is this accpetable or does the slit in between the tabs need to be away from the edge?
I figured it up that if i move everything another 3" to the right or left, It will work out where I don't have a slit on the edge on either end. Is this acceptable?
J S Machine is offline   Reply With Quote
Old 03-17-2011, 08:53 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
You've got it figured out.
seeyou is offline   Reply With Quote
Old 03-17-2011, 08:53 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
That'll work fine
Good catch before you just started throwing 'em down
tcleve4911 is offline   Reply With Quote
Old 03-17-2011, 09:12 AM   #4
Lost..
Rewards Points: 336
So I do need to move them an aditional 3" or so to the right to avoid the slit on the edge?
Old 03-17-2011, 09:23 AM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Take the time to just dry-lay a couple of courses and see what it gives you.
As long as the slots line up and you don't have taps less than 3", you'll be fine.
BTW this is why architectural shingles are so popular.
You don't have ANY of those layout problems....
Old 03-17-2011, 09:30 AM   #6
Lost..
Rewards Points: 336
Oh I wish I did have architectural shingles. My house was built in '98, and a new roof added in '06 right before I bought it. They put regular 3 tab back on. I wish they would have done architectural because in my opinion they look so much better. According to my HOA rules, any other structure built on my property has to have the same roof. So, I have to put driftwood 3 tabs on this shop I'm building.
If I do it the way I had figured up and move everything an additional 3" to the right, it will create a tab every other row that is a little less than 3". Will this suffice or since it is actually less than 3" should I go with something different?
Old 03-17-2011, 10:06 PM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
The little tab will be fine. It just looks funky.
If you're really concerned about the 'little tab',
ask your shingle supplier for an IKO 3 tab shingle
They're Canadian metrics so each tab is 13" plus instead of 12" american.
.....or add another shadow board to your rakes to build it out more.
Tell me about roof coatings for an older roof Leica Roofing/Siding 3 09-19-2010 01:55 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-20-2010 11:50 PM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 05:48 PM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
