Need Help Deciding Giving This Chimney Flashing Contractor A Second Chance - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-15-2011, 10:29 PM   #1
Need help deciding giving this chimney flashing contractor a second chance
His flashing is leaking extensively. Brand new roof installed this summer, hired a "professional" to handle the chimney repair and flashing so that it would be done right... ha.
He's agreed to come back and reflash, but said this in his email...
"I will remove all the counter flashing and reinstall it without any historic flashing in place. I can not go back to the step flashing because of the grind line, but I promise that when I am done, my flashing will not be the cause of the leaking."
I didn't understand the bit about the step flashing not being able to be removed (its old flashing he was suppose to replace).
Should I trust him?
tracyj is offline   Reply With Quote
Old 03-16-2011, 05:40 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
No. Call someone else.
seeyou is offline   Reply With Quote
The Following 3 Users Say Thank You to seeyou For This Useful Post:
mem (03-16-2011), MJW (03-16-2011), Slyfox (03-16-2011)
Old 03-19-2011, 07:46 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
When I remove and replace counter flashing sometimes creating a new grind line is required.IMO the old counter flashing has to be removed.I always remove the old and install the new.If I am not mistaking that was the reason for installing the CF with the new roof.
Try calling and make an appointment for him to return and explain his intentions.
Roofmaster417 is offline   Reply With Quote
Old 03-29-2011, 10:56 AM   #4
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Tear off the metal, tear off the shingles around the chimney, pre flash with ice and water shield, ne step flashing as necessary, custom bend stepped counter flashing, saw cut mortar joints to match the steps in the counter flashing, install flashing, seal with POLYURETAHEN caulk.
LOL he can't grind the mortar joints?! LOL.
Flashign a chimney takes definite know how, and there is more to it than my run on sentence above, but if he doesn't know how to gring or saw cut mortar joints for the flashing forget about him.
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Bad job replacing chimney flashing? TNVolFamily Roofing/Siding 12 02-28-2010 08:04 PM
Chimney peak flashing richbl Roofing/Siding 5 09-29-2009 06:23 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 11:00 PM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 11:27 AM
Looking for Chimney Flashing Kit. Prefabricated? gante Roofing/Siding 11 02-27-2009 10:11 AM
