Need Help Chimney/stink Pipe Flashing Leak Pics - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-26-2010, 09:34 AM   #1
Rewards Points: 93
Need Help Chimney/stink pipe flashing leak pics
I recently had a roof replace (4 years ago), I notice a few places leaking recently. When it rains water runs down the chimney and the stink pipe inside the house. One is around the chimney where it is flashed and the other is around the stink pipe. I recently went on the roof to investigate and found the issue on at least the chimney. It appears the flashing goes into the mortar and then they used almost like a calking which has separated and left gaps. From looking at the pictures can u tell me the best way to permantly fix this? How it is supposed to be done/flashed and does everything look correct. The other area, Around the stink pipe, I can't seem to find where it is coming in from? What are some normal culprit areas? Does this looked flashed correctly? Doing some work and want to address and correct the problem for good. The roofers are no where to be found and other than these areas they did a great job. The roof is also a very very shallow pitch. I have attached some pictures. Thanks for any and all advice and fixes you can offer. Can't seem to attach pictures, may have to wait till I get home, but I'll try again
bfan781 is offline   Reply With Quote
Old 03-27-2010, 07:25 AM   #2
Rewards Points: 93
let me try this again...
Need Help Chimney/stink pipe flashing leak pics-dsc07264.jpg   Need Help Chimney/stink pipe flashing leak pics-dsc07267.jpg   Need Help Chimney/stink pipe flashing leak pics-dsc07270.jpg
Old 03-27-2010, 11:18 AM   #3
First off I am not a roofer but there's a few things that I see that might need to be addressed.
The boot around the stink pipe looks like it was installed the wrong way, I believe the hump in the metal between the flat metal and the rubber boot has to be facing up the roof.
As for the chimney it looks like they ground out the grout and installed lead step flashing and apron but I can't see if (or possibly how) the step flashing is woven into the shingles going up the side. I'm also not sure what caulk they used to seal the grout joint, but looks like they might not have used the right stuff and not have put enough of it in the joint. If you are looking to re do the caulking in the grout you can look into a line of sealants called geocel. I believe Geocel 2300 is what I would use.
If the step flashing is not woven in with the shingles I'm not sure how that could be repaired without pulling out the flashing and redoing it.
SleepnZJ is offline   Reply With Quote
Old 03-27-2010, 01:00 PM   #4
The stink pipe looks like it is not the problem. It is done fine.
The shingles along the side of the chimney look like they were not properly flashed. It looks like they just laid the shingles on top of the lead, instead of using proper step flashing. From the pictures, that would be my first guess.
BamBamm5144 is offline   Reply With Quote
Old 03-27-2010, 01:31 PM   #5
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Like BamBam said. Only thing wrong with pipe is it's cut too tight. 1/2" play would have been more irght, but it's OK.
No step flashing visible on chimney.
tinner666 is offline   Reply With Quote
Old 03-27-2010, 01:37 PM   #6
Pro Slate Roofer
tinner666's Avatar
"other is around the stink pipe. " Look closely to see if the rubber is seperated from the metal of the collar. or not tight to the pipe.
A third look tells me the water is getting in where the laminated shingle parts form a 'step' on the first shingle that covered pipe metal. Cut them back about 1/2" or so to eliminate that issue.
Old 03-27-2010, 11:19 PM   #7
Commercial Roofing
AaronB's Avatar
The pipe boot is installed in the proper direction. The "hump" as you call it is meant to be in front to accommodate differing roof pitches.
The chimney flashings were never completed. Im glad to see them using lead wedges to anchor the flashings, but they must be installed properly and the joint either filled with mortar, or at absolute minimum FILLED with caulk and tooled so that the caulk mates with the masonry.
Now... caulk on the lead seam is doing you no good and will fail shortly. This joint should be welded.
And I agree that there is no step flashing visible, so I cannot say if it is there or not.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-28-2010, 07:17 AM   #8
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Looks to me like they may have done the one piece flashing trick, where they run the counter long out on the roof instead of installing separate base flashings. I don't like that detail, but I've seen it work. I suspect the poorly filled reglet and would try fiiling it properly before messing with anything else.
Those neoprene gasket WV boots are my #1 service call problem We replace 200-300 a year, most of which are less than 3 years old. I'd replace it with a lead or copper boot.
seeyou is offline   Reply With Quote
Old 03-28-2010, 05:24 PM   #9
old timer
Chimney flashing
That chimney is a mess. Looks like peel and stick. One piece apron and sides. Joint not sealed.
Try looking here for
links not working - Moderator
dmc@RCR is offline   Reply With Quote
Old 04-01-2010, 01:10 PM   #10
Rewards Points: 93
Sorry for not getting back here quicker, I have been dealing with other rennonvations. The weather is looking good around here this weekend and I want to address this issue. There has been a lot of good feedback given and I want to try and fix this correctly and permantly without totalling starting from scratch unless I really have too.
So just to clarify, what should I attempt to do first to resolve the leakage? As far as the chimney flashing, I won't for certain know until I get up there, but someone mentioned that it maybe a one peice trick at can work, but may not be the best method. The gap where the sealant /caulking is is quite large and that appears to at least be the main culprit. Should I at least first start wtth digging that out, at filling with mortar? Do I need to set the lead wedge in a little to have the mortar cover?
As far as the pipe, someone mentioned, "A third look tells me the water is getting in where the laminated shingle parts form a 'step' on the first shingle that covered pipe metal. Cut them back about 1/2" or so to eliminate that issue", does that mean cut the rounded asphalt shingles back? Little confused on that.
BAsically I want a good solid fix without nessarily ripping out and re-doing. Anymore input would be great!!
Old 04-01-2010, 01:58 PM   #11
old timer
Hmmm, those links should work. Let's try again.
http://www.chimneyflashing.info/
http://www.chimneyflashing.info/Copp...-Flashing.html
Without starting from scratch, you could just clean the existing joint of old caulk and re fill.
Take a look at the vent pipe flashing next to the chimney on the second link.
Old 04-01-2010, 03:57 PM   #12
Pro Slate Roofer
tinner666's Avatar
BAsically I want a good solid fix without nessarily ripping out and re-doing. Anymore input would be great!!"
Larger item, but note the relief around the pipe. When shinglesa re cut tight, water does get under them and looks for an exit.
http://www.albertsroofing.com/Power%...stallation.htm
leak around stove pipe greenvorlon Roofing/Siding 2 10-13-2009 01:38 PM
Pipe in Sycamore - yet another mystery - Pics Leah Frances General DIY Discussions 17 07-02-2009 12:01 AM
pipe leak & sheetrock damage santogr General DIY Discussions 2 03-04-2007 01:44 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 08:32 PM
