Need Gutters On Dutch Colonial Slanted Fascia - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-02-2012, 07:06 PM   #1
Need Gutters on Dutch Colonial slanted fascia
Need to have gutters installed on and old dutch colonial with fascia that is half slanted and half straight and have a few questions hope someone can help with.
When we bought the house there were some hangers left over on the upper roof, you can see in the pic.
Front and back of house are the same, upper and lower level roof straight across about 25ft, lower is a few feet longer.
  • Do we need gutters on both levels?
  • Should the hangers be attached to the slanted or straight part of fascia?
  • If we only need them on upper level, how would the spout get down and around the lower level roof line?
jgjh151 is offline   Reply With Quote
Old 10-02-2012, 07:10 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Put gutters on both levels.
They can be hung on the sloped sections with angled hangers.
Empty the trough from above into the trough below along that outside corner post.
Old 10-02-2012, 07:25 PM   #3
Rewards Points: 2,212
Better if you can to run it to ground and not dump into another eaves trough.
mae-ling is offline   Reply With Quote
Old 10-02-2012, 07:29 PM   #4
Rewards Points: 14,306
What style gutters do you plan on installing? Those were for round gutters and they used the wrong style bracket for that type fashia.
They need to be the type that mount under the shingles and hang over the edge.
http://www.guttersupply.com/categori...Code=p-gutters
Old 10-02-2012, 07:39 PM   #5
"What style gutters do you plan on installing? "
No idea, what do you recommend?
Old 10-02-2012, 07:51 PM   #6
Round gutters will cost far more and at least in my area are near imposable to find,
I have not installed my own gutters for years I call the seamless gutter company to make and install them. I then get a great looking leak free gutter.
Old 10-02-2012, 10:57 PM   #7
Agreed, however, that may look a bit weird in this case.
Also, the amount of moisture hitting the lower gutter from the direct roof moisture on that capture surface is so minimal, it is not as if it will be overcome by that volute.
The rest of the roof surface is not so significant that it should overflow the gutter system in any capacity.
Old 10-30-2012, 06:34 AM   #8
We had gutters put on, some issues though, not too happy.
Some are too short.
Back gutters use smaller wedges than front even though fascia is the same.
Front of house wedges are smushed and visible.
Front gutters are flat while back gutters slant with roof slant.
Front has a wedge on fascia where gutter is too short.
Correcting all this is reasonable request right?
Old 10-30-2012, 06:46 AM   #9
What would the correct wedges or hangers looked like? I'd like to try to find a pic from google to see the difference with what was used and what should have been used.....if anything. Maybe these are right, looks weird but not sure.
Old 10-30-2012, 09:08 AM   #10
That's a mess, they left you short on one side and tryed using the wrong off the shelf standoffs.
What I have done and it worked perfect was make the stand offs out of 5/4 vinyl lumber. I just cut one side to match the profile of the fashia, leaving the other side plumb.
Old 10-30-2012, 10:22 AM   #11
That is not acceptable.
Old 10-30-2012, 10:48 AM   #12
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Most likely the fascia isn't slanted but there is a crown molding behind the aluminum trim. The aluminum trim makes it looks slanted because the siders bent a slant in the aluminum fascia to cover the molding.
You may install "hanging" gutters with straps, sometimes called vampire straps. I do not know why they are called vampire straps, just a slang I guess http://www.guttersupply.com/m-alumin...le-t-bar.gstml
Wedges may also sometimes be used: http://www.guttersupply.com/m-alumin...er-wedge.gstml
This assumes you will be installing a K style gutter though half round may be more appropriate http://www.gutterexperts.com/aluminum-gutters.htm
I would place gutters on upper and lower and I would certainly use the oversized 4" downspouts on the lower, though it wouldn't hurt to use the oversized downspouts on the upper as well. I would extend the upper downspouts directly into lower gutter meaning they do not drain on the roof, but have an extension into the gutter.
OK follow up to your 2nd posting. The short gutters need to be replaced. That's just not acceptable! These people were NOT professional in my opinion.
The wedge issue is up to you. That seems to be purely cosmetic. I would have used all the same size to avoid this kind of customer complaint. Actually this is why I would have opted for hanging style gutters instead of wedges.
Joe, I once used cedar to do as you said. We used cedar since the fascia was cedar. It worked perfectly. We used 2" instead of 5/4" however. The vinyl lumber idea is a good one actually.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Tags
dutch colonial , gutters , slanted fascia
Vinyl fascia and gutters lonewolf_one Building & Construction 3 08-16-2012 11:40 AM
Gutters and fascia replacement Bmc General DIY Discussions 10 04-22-2012 03:51 PM
Gutters and Decorative Trim on Fascia paulyg Roofing/Siding 12 07-27-2010 02:54 PM
Add Vinyl/Aluminum Fascia and Aluminum Gutters cward Roofing/Siding 2 10-26-2009 07:35 PM
Advice on installing gutters on slanted fascia notfromaroundhere Roofing/Siding 3 12-27-2008 04:34 PM
