Need Advice On New Roofing System - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-09-2011, 05:00 PM   #1
Need advice on new roofing system
I have a 10' X 22' metal roof that has styrofoam incased inside of the metal (have no idea what this product is called).
This is on a outdoor aluminium lanai that I use as a living space. the roof is like said aluminium with styrofoam inside as insulation. they are 10' by 4' panels that i suppose groove together but are leaking in some of the seams.
There was butyl tape and silicone put down the seams but i dont think they had uv protection and have given in to the weather.
My questions are these (opionions appreciated)
1) should I take off old buytl tape and clean before fixing with new product?
2) should I just fix with a uv approved butyl tape like eternabond? is this good stuff (I live in florida and is exposed to max sunlight)
3) Should I think about covering the whole roof with a uv rated type of peel and stick or should I use a torch down material.
I would like some kind of insulating roof product if I should do the whole roof what is the best product for my style of roof?
4) I know that I could remove the old butyl tape and clean and use a white roll on roof kind of thing but doesn't this stuff start peeling up after awhile and cause a big mess?
kiddthunder is offline   Reply With Quote
Old 07-09-2011, 08:26 PM   #2
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Silicon sucks because silicon only sticks to silicon. Are you sure it's silicon or are you using that as a generic term for caulk?
Contact a roofing contractor to install a flute fill single ply roofing system.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-24-2011 11:58 PM
Metal roofing questions Axhammer Roofing/Siding 17 08-10-2010 09:10 AM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
Need Roofing advice robynliz General DIY Discussions 3 02-27-2009 07:17 AM
