Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-10-2010, 07:05 PM   #1
Need advice, my roof blew off
A year and 5 days ago I had a torch down roof installed on my new shed dormer. It was done by the contractor, not a roofing company. Two days ago during a storm with 60mph winds the whole roof (35'x16') ripped off the back of the house, flipped over the ridge and damaged the chimney. I'm now dealing with him and determining what he is liable for. I spoke to a friend of friend about it today. He said he does a lot of roofing so I wanted to pick his brain as to why my roof would have failed so easily. He was pleased to learn that the torch layer did not separate from the base fiber layer, but was disappointed to learn that the base fiber layer was installed with pneumatic coil roofing nails, not cap nails. Evident now that the complete roof now laying on my front lawn up side down, I can see tons of holes in the base layer where the small nail heads tore right through. They were nailed in 3 rows per 36" sheet, about every 10", but I guess that wasn't enough? Before I confront my contractor on this I was looking for some advice. Would not using cap nails allow the complete roof to rip off the sheathing like that?
TReally is offline   Reply With Quote
Old 05-10-2010, 07:08 PM   #2
wow
The older I get the better I was
Old 05-10-2010, 07:17 PM   #3
Check the installation details of the manufacturer.
rustyjames is offline   Reply With Quote
The Following User Says Thank You to rustyjames For This Useful Post:
oh'mike (05-10-2010)
Old 05-11-2010, 01:54 AM   #4
Commercial Roofing
AaronB's Avatar
Yes it would. You would need a minimum of steel cap nails.
Use a qualified roofer for roofing.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 05-11-2010, 09:45 AM   #5
Holy crap, That is a big peice too. Yea I would not make that contractor fix this, just try to get him to pay for a roofer to do it right.
slickgt1 is offline   Reply With Quote
Old 05-11-2010, 09:50 AM   #6
I'd think that screws would be worth looking into, instead of nails.
igneous1 is offline   Reply With Quote
Old 05-13-2010, 11:51 AM   #7
ews
Portlander
ews's Avatar
Next time get roofing work done by a roofing contractor
ews is offline   Reply With Quote
Old 05-13-2010, 12:44 PM   #8
Make sure you talk to your insurance agent. It's likely covered and they will likely pay enough to use a real roofer (minus the deductable)
Old 05-13-2010, 12:49 PM   #9
Shut in w/o Home
seeyou's Avatar
Holding power is not the issue here. The nails are all still stuck in the sheathing, but the base sheet they were nailed through tore around the nails. A nail with a larger head would be the proper fastener. The wrong nails were used. Screws would have had even less bearing surface on the base sheet.
seeyou is offline   Reply With Quote
Old 05-13-2010, 02:44 PM   #10
Commercial Roofing
AaronB's Avatar
If we are talking screws with plates, then I would say they CAN hold better, if you use the proper amount.
On the other hand, I have never used screws direct to wood, as ring shank or spiral shank at the proper installation pattern have always done the trick. Never had a pullout or blowoff issue with them. Smooth shank nails tend to pull out more easily, although all roof blow offs I have ever repaired on shingle roof have been with shingles blown off, and the shingles had torn through with the nails still in the deck.
Old 05-13-2010, 03:12 PM   #11
Shut in w/o Home
seeyou's Avatar
You are correct, sir. And that's how we install insulation and recovery board under membrane. I've never seen the base sheet screwed down, though. Never seen it nailed with roofing gun nails either.
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 04:42 PM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 08:25 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Flat Roof Advice ajoantmug Roofing 4 03-11-2008 11:02 AM
getting outside advice Unregistered Roofing 1 12-27-2003 06:05 AM
