Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-30-2011, 11:18 AM   #1
need advice installing soffit vents in vinyl siding
Hi- yep, I'm new! I've searched but haven't quite found the answer for my specific situation, so it's time to post!
Little background on my house attic/roof in general- it's about 1000 square feet. The garage is attached. I have only 4 roof vents (think I need to add more in the spring), and 2 gable vents. One of them is basically the big entrance into the attic from the garage deck.
Because the insulation situation up there was terrible, and consumer's energy had a rebate program before the end of the year, I blew in fiberglass insulation to about R-50 or 60 just recently. I installed baffles every few rafters and marked on the outside where they were for future soffit vent installation (in hindsight maybe I should have done them all, but just too much work).
My soffits (eaves?) hang over only about 6-8" before the gutter, and are basically 1" wood covered by vinyl siding. My plan was to simply cut rectangular holes and cover them with the louvered vent covers you can buy from home depot. Well, I got to it with the sawzall, but then realized that installing those louvered vents will leave open gaps where the siding is grooved. I guess my concern is that bees will make nests in my attic in no time flat, and it would be a pain in the butt to fill every gap with caulk, not to mention look like crap. Any ideas? I don't know if I can replace the whole thing with a vented vinyl soffit, but even if I do I feel like it wouldn't be very much ventilation compared to the louvered vents.
Thank you!
tspoon84 is offline   Reply With Quote
Old 12-30-2011, 12:08 PM   #2
MarginallyQualified
1) remove the existing vinyl altogether.
2) butcher up some vent opening holes (neat is better) as needed.
3) use the vented material intended for soffit to close.
hth
Old 12-30-2011, 10:41 PM   #3
Moderator
"I don't know if I can replace the whole thing with a vented vinyl soffit, but even if I do I feel like it wouldn't be very much ventilation compared to the louvered vents." ---- You are correct! The NFVA with vinyl vents is minimal with only the existing 6-8" soffit area depth. The vinyl only has one that meets minimum 9 sq.in. per foot (recommended) and you have 1/2 that. I'd use continuous venting (screened and opposing louvers, metal), close the fascia board for optimum positive air pressure. Then ? next to that.
Gary
PS. Welcome to the forums!
Clothes taking longer to dry?
Old 01-05-2012, 10:09 PM   #4
Take all the vinyl soffit down, buy full-lanced aluminum soffit material in the correct color, cut the soffit wood board back completely, install the full-lanced aluminum.
Block the gable vents.
Add at least one exhaust vent.
Double-A is offline   Reply With Quote
Old 01-05-2012, 10:20 PM   #5
A picture would sure be nice.
vinyl siding over asbestos?? Buckeyes97 Remodeling 12 08-21-2012 10:20 PM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing 1 09-07-2011 11:13 AM
vinyl Siding / Soffit Question J S Machine Building & Construction 42 04-18-2011 11:11 PM
How to cut vinyl siding to vent bathroom fan? db_9 General Discussion 9 11-13-2009 01:58 AM
Vinyl soffit and fascia msyv Building & Construction 7 09-13-2009 11:21 PM
