Need Advice On Attic Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-07-2010, 08:03 AM   #1
Need advice on attic ventilation
I have a 1948 brick and block house with a rectangular cross-section (36’ x 23’) and a gable roof. There are no soffit vents and no space at present to install them. The gable vents (12” x 18”) are considerably undersized (following the air vent, inc methodology). There is an attic exhaust fan with a mushroom cap. I don’t know the exhaust rate of the fan, but the motor is 1/20 hp, 1500 rpm and the blades are 14”. The attic gets hot - today, the air temp was 80 F and the attic was 110 F. The roof itself has 5 -10 years of life left. I would like to improve the situation, but I’m not sure the “best” way to proceed (a balance between results and money), but I would appreciate any input from the experts.
Thanks guys great site.
sihaba is offline   Reply With Quote
Old 05-07-2010, 12:43 PM   #2
Commercial Roofing
AaronB's Avatar
There are fascia venting options available.
http://www.gaf.com/Roofing/Residenti...ascia-Vent.asp
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 05-07-2010, 01:55 PM   #3
You definitely need to add more intake ventilation if you have none currently, but 110 degrees is not bad at all.
Ed
Ed the Roofer is offline   Reply With Quote
adding attic ventilation DIYGST HVAC 4 04-16-2010 10:33 PM
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 09:05 PM
Attic Ventilation Question… champy2008 Building & Construction 4 09-16-2008 07:03 PM
Attic ventilation question tpagel Building & Construction 4 04-15-2008 12:22 AM
Attic Ventilation - importance of balance FatAugie Roofing/Siding 7 08-04-2007 10:57 AM
