Need Advice - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-01-2009, 09:05 PM   #1
Need advice
We got some carpenter ants in the kitchen. A house inspector told us that part of the fascia (that is covered with aluminum) is rotten and the ants probably come from the rotten wood above, as I see them climbing the wall outside and getting in through a gap in the aluminum soffit. My roof is only 2 years old and is in very good shape.
What is my best solution to avoid ants in the future?
Pest control companies will only spray and dust and will not repair the rotten wood.
1. Replace ALL wooden fascia and soffit and cover it again with aluminum
2. Replace all wooden fascia and soffit and not cover them again
3. Replace only the rotten parts of wood and use the same aluminum cover
4. Any other long lasting solution?
Rodi is offline   Reply With Quote
Old 07-01-2009, 09:34 PM   #2
I have run into those pests in the same situation, where the eaten through rotted fascia boards were covered with an aluminum cladding.
We replaced all of the wood on that side. Then, we not only sprayed some ant poison spray, but also sprikled 1-2 containers of ant poison powder in all of the area, so that any remaining ants would track the poison to their nest.
That seemed to do the trick.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-02-2009, 07:13 AM   #3
One solution, replace the wood with composite or cement trim.
Old 07-02-2009, 08:46 AM   #4
MJW
A picture would be nice.
Usually it is improper siding or flashing details. Just replacing it won't fix the problem.
To get rid of the ants, remove all of the wood that is wet and let the area dry for a day (at least). Then replace.
MJW is offline   Reply With Quote
Old 08-13-2009, 08:43 AM   #5
the Musigician
DangerMouse's Avatar
as i'm framing the new sections of this house, i'm sprinkling boric acid on the sills before i insulate and drywall.
it'll last forever and kills any insects that walk on it. just an fyi
DM
Old 12-30-2009, 11:30 PM   #6
The problem with C-ants is almost always associated with moisture. Keep it dry and that is the best deterrent.
Unfortunately the boric acid will not last forever. Moisture will eventually cake it up and all you'll have is some extra plaster of sorts or new dust will cover it in time and it will be harmlessly buried.
The Bug Doctor is offline   Reply With Quote
Old 12-31-2009, 12:34 PM   #7
Dave The Roofer
Dave The Roofer's Avatar
Send a message via AIM to Dave The Roofer
Change any wet wood first
Hello you will want to change any rotten wood first, and then cover the wood with trim coverage.
Dave The Roofer is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
I need advice on a flat roof Krissy Roofing/Siding 10 12-27-2007 02:55 PM
