Is It Necessary To Put A Ridge Vent On A Detached Garage? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-23-2014, 10:42 AM   #1
Rewards Points: 170
is it necessary to put a ridge vent on a detached garage?
The garage is unheated. No ceiling (just rafters). I will be reroofing a gatage come spring and the homeowner requested a risge vent because when a roofing company did her house they installed one on the house which is good, but i dont see the purpose of one on a detached garage. Maybe im missing something?
diyer111 is offline   Reply With Quote
Old 01-23-2014, 10:55 AM   #2
Rewards Points: 13,750
It helps vent out the hot moist air in the summer, keeps the whole inside of the garage cooler, shingle will last years longer.
Well worth what little they cost.
Old 01-23-2014, 03:49 PM   #3
Rewards Points: 170
Alright, thanks when the spring comes and the snow melts i will install it while reroofing the garage.
Old 01-23-2014, 03:49 PM   #4
Rewards Points: 170
The Following User Says Thank You to diyer111 For This Useful Post:
oh'mike (01-23-2014)
Old 01-23-2014, 04:47 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
Not completely necessary given that the space is not conditioned but it will help with the items that Joe mentioned. They are cheap. Stick one on.
Old 01-23-2014, 08:04 PM   #6
Registered User
Rewards Points: 5,516
Absolutely necessary for the life of the roof framing, IMO. Drive in to garage (from a trip long enough to have the heater inside working) with snow/water on the vehicle, hot engine, brakes, exhaust, radiator, pumps, tires, wheels, warm metal on the vehicle; all cause the moisture to turn to vapor- rising up due to warmth, wetting your wood framing leads to rot. A top vent would solve most of the vapor condensing, allowing it to leave before landing on the much colder framing.
"Maybe im missing something?"--- don't feel badly, many miss it.... lol.
Gary
Old 01-24-2014, 03:39 AM   #7
roofermann's Avatar
Rewards Points: 401
The others have mentioned the moisture issues. I would install for appearance too. OP says it's on the house.
roofermann is offline   Reply With Quote
The Following 2 Users Say Thank You to roofermann For This Useful Post:
oh'mike (01-24-2014), Windows on Wash (01-24-2014)
snow country ridge vent on 2:12 pitch roof fxtm Roofing/Siding 4 11-01-2011 06:26 PM
OK to put ridge vent on garage amdspitfire Roofing/Siding 3 09-09-2010 09:06 PM
wiring 100A to detached garage snowman Electrical 4 11-28-2009 04:53 PM
Insulation questions for new detached garage mpt1123 Building & Construction 2 03-01-2009 08:18 AM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
