Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-01-2011, 12:48 PM   #1
Nearly flat roof, with ventilation pipe, ice dams / leak - suggestions needed!
We currently own a 2-story duplex, and last winter we had water leaking in around a toilet vent pipe that runs vertical through the external wall, and out the roof about a foot from the edge. There is as much insulation as possible in the area, however the heat is causing the snow to melt, and creates ice jams, backing the ice up to the vent pipe, where it's entering. The ice only needs to backup about a foot before it reaches the pipe.
There is also another issue, where ventilation can not really happen with what's there - The ceiling in the top floor is only about 6'3". From what I understand there is room for insulation, and not much more for anything else. I think the correct and most expensive fix is to increase the slope, maybe sloping a 2x12 on top of the current roof, and adding in a vent on both sides.
Would it be possible to strip down to around the vent pipe, add a better boot, and then tar over the whole section of roof?
What's the best / cheapest way to fix the problem?
Attached is a pic of the problem.
highvoltz is offline   Reply With Quote
Old 11-01-2011, 01:27 PM   #2
What kind of roof is the flat roof?
remove the shingles around where the flat area connects to the house and around the vent. Apply Ice and Water shield and new shingles. This is only a bandaid and your idea of increasing the slope is the easiest/cheapest fix.
shazapple is offline   Reply With Quote
Old 11-01-2011, 02:05 PM   #3
For that flat section, its roll roofing
Old 11-01-2011, 04:53 PM   #4
Exterior Construction
Windows on Wash's Avatar
Make sure the drywall/structure on the living side is air tight and ventilation requirements are probably little to none.
Old 11-01-2011, 05:20 PM   #5
Super Moderator
Bad design --and ugly,to.
I'd reframe the roof so you have a decent pitch--4/12 or better----
But I'm a carpenter ----a roofer might have a better solution.
AndyGump (11-01-2011)
Old 11-01-2011, 07:35 PM   #6
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
The best and cheapest (in the long run) is to raise the ceiling in that bathroom to something decent and build a new roof gable that will over-frame onto the main roof.
This is something you can DIY.
Andy.
AndyGump is offline   Reply With Quote
Old 11-02-2011, 10:49 PM   #7
Thanks Guys
Flat Roof Resurfacing - Where to start? adamgram Roofing 9 09-05-2010 10:54 AM
Help with Roof Leak ak1mking Roofing 15 11-14-2008 02:55 AM
Tired of patching my flat garage roof, I want to reroof it. Metal???? sellingitall Roofing 2 09-12-2008 09:51 PM
flat roof leak snikda9 Roofing 16 01-26-2006 05:25 PM
Need Help on the Flat Roof and more... MelindaA Roofing 12 12-21-2005 11:12 PM
