Nails Through Ceiling In Attic - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-30-2012, 11:28 AM   #1
nails through ceiling in attic
I have some crawl spaces in a spare bedroom and I noticed that alll through the roof there are nail protruding through. I am not 100% sure if they are whats holding the shingles down but my question for you guys is if this is normal for them to be protruding through? I have attached some pictures so you can get a better idea. Thanks a lot! Love this website.
mckain0919 is offline   Reply With Quote
Old 10-30-2012, 11:39 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,786
Yes. Very normal.
Watch your head.
Old 10-30-2012, 11:41 AM   #3
Great! Thank you very much!
Old 10-30-2012, 01:12 PM   #4
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Normal and as intended, http://www.certainteed.com/resources...arkInstall.pdf "On thinner decks, nails must go at least 1⁄8" (3.2 mm) through the deck."
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 10-31-2012, 06:58 PM   #5
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Yep! On plywood decks, they must protrude.
tinner666 is offline   Reply With Quote
Old 10-31-2012, 07:09 PM   #6
Registered User
Rewards Points: 5,520
It's unanimous (if asphalt shingles above)!
"R905.2.5 Fasteners. Fasteners for asphalt shingles shall be galvanized steel, stainless steel, aluminum or copper roofing nails, minimum 12 gage [0.105 inch (3 mm)] shank with a minimum 3/8-inch (10 mm) diameter head, ASTM F 1667, of a length to penetrate through the roofing materials and a minimum of 3/4 inch (19 mm) into the roof sheathing. Where the roof sheathing is less than 3/4 inch (19 mm) thick, the fasteners shall penetrate through the sheathing. Fasteners shall comply with ASTM F 1667." From: http://publicecodes.cyberregs.com/ic...9_9_par025.htm
I would store any items/electronics in a air-tight container due to the flying fiberglass fibers everywhere in your attic air space,
not even mentioning the possible moisture present...
Gary
Old 11-02-2012, 08:16 PM   #7
CIT
As long as you don't see them protruding through the open eaves outside your house, the nails in the attic are normal.
CIT is offline   Reply With Quote
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 11:50 AM
Help...Framing Door Along Slanted Ceiling of Attic Space JDinh1985 Building & Construction 5 09-25-2011 10:50 PM
Sagging Ceiling Joists - Adding Beam In Attic DoItMyselfToo Building & Construction 11 11-30-2010 06:20 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
