Nails, And How To Use Them - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-08-2011, 05:15 AM   #1
Rewards Points: 107
Nails, and how to use them
Im going to be getting my roof replaced here hopefully in a few weeks.
Is there a benefit to using 6 nails over 4 for my roof? I have a roof that goes from 15/12 to 12/12.
Also should I have the roofer use a nail gun or hand nail the shingles on? He has 2 crews and said there is no cost differance, just that it may take a day longer on my roof.
Mr Smiley is offline   Reply With Quote
Old 09-08-2011, 08:13 AM   #2
Rewards Points: 83
6 nails will hold the shingle better than 4 on those slopes.
Nailing with a gun is just as good (if not better) than nailing with hand nails if it's done properly.
bcdemon is offline   Reply With Quote
Old 09-08-2011, 11:46 AM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Most manufacturer's specs call for 6 nails/shingle on slopes over 12/12.
+1 on the no difference in the hand/gun nail debate if done right. Most gun nailers tend to use more nails than hand nailers.
seeyou is offline   Reply With Quote
Old 09-08-2011, 11:54 AM   #4
Experienced
Jackofall1's Avatar
The question I have and you should as well, your contractor has indicated to you that the extra day it would take to hand nail it, costs the same?????
Whats wrong with that picture.
An extra day for the crew, should equate to extra dollars in cost.
Just my opinion
Mark
The Following 2 Users Say Thank You to Jackofall1 For This Useful Post:
AndyGump (09-08-2011), seeyou (09-08-2011)
Old 09-08-2011, 01:10 PM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,342
With older cracked and knotty sheathing, you sometimes cannot tell if you nailed into nothing, if you use a nailer. That's the only benefit to hand nailing.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-09-2011, 07:16 AM   #6
Rewards Points: 83
An experienced gun operator knows the sounds and feels his tool makes. Going into wood is definitely a different sound and feeling than missing.
The Following User Says Thank You to bcdemon For This Useful Post:
kwikfishron (09-09-2011)
Old 09-09-2011, 08:38 AM   #7
I have gas!
I think the experience part plays a pretty big role. For my own experience, I have come across a shingle that was entirely nailed in the space between the planks. It was essentially being held in place by the glue on the shingle.
