Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-25-2009, 10:31 PM   #1
Nailing up aluminum fascia cover
I am installing aluminum fascia cover on existing 1 x 6 fascia boards, while nailing though the aluminum I seem to get slight flaws or ripples in them. These covers are 10' long what is the suggested method for nailing them up?
pstasuik is offline   Reply With Quote
Old 01-25-2009, 10:46 PM   #2
tomstruble's Avatar
lots of things you can try,pre drill holes slightly larger than your trim nails,dont nail to tight,dont push your trim pc up to tight just try to float it on the wood.You can do all these things and more, then the sun will hit it and expansion will most likely cause ripples.you can also have the facia made with a hem or fold at the top that will help.It seems like a simple thing but it takes some experience to get it flat.Are you going to install a gutter over the fascia?Then the small ripples dont really matter good luck
tomstruble is offline   Reply With Quote
Old 01-25-2009, 11:05 PM   #3
You only need to use 3 to 4 nails tops to hold the fascia on and they should never be nailed in the face. Only nail on the bottom lip underneath. Sometimes a shingle nail sticks out underneath the drip edge and doesn't allow the fascia metal to slide up...or even a sliver of wood. The only other cause for ripples is the fascia not being straight. Metal will ripple when bending it like a banana. You may have to cheat it so you don't have the ripple.
Josh Jaros
jaros bros. is offline   Reply With Quote
Old 01-25-2009, 11:20 PM   #4
tomstruble's Avatar
good tips josh
Old 01-25-2009, 11:25 PM   #5
Thanks guys!! Just to clarify I should never nail the fascia horizontally just vertically? I perhaps forgot to mention that I am using the fascia cover as a cheater "J" trim to support alumiunum vented soffit, if I nail up through the bottom will this not interfere with sliding in or installing the soffit? By the way I will be adding gutters so that will hide most of the ripples. To date I have been using 4 alumiumum nails per 10' section of fascia in the face or horizontally my thinking was they would be hidden by gutters or drip edge.
Old 01-25-2009, 11:34 PM   #6
You should have installed the soffit first. The only time you install it first is for the prefab and the rolled soffit which I don't think is even made any more. The soffit should be nailed in place to keep the wind from blowing it around and that will be hard to do with it covered up on the end.
Josh Jaros
Old 01-26-2009, 12:16 AM   #7
tomstruble's Avatar
Josh is right .In your situation you want to nail your soffit to the 1x6.If you have the trim on aready you can take a nail punch and punch the trim nails right thru the aluminum,install your soffit then the aluminum facia you can fill the small holes you punched thru with a trim nail or alittle caulk then install your gutter.good luck
Old 02-10-2009, 07:21 AM   #8
the roofing god's Avatar
Send a message via MSN to the roofing god
most don`t nail thru the bottom lip of the fascia cover,thru the soffit up--nail the soffit to the bottom edge of the fascia,the put the fascia cover in place,and nail it when you have the whole piece in place,and yes 4-5 nails are plenty,nail where the gutter will cover,and make sure not to nail thru 2 pieces at laps,as it will bubble out
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 03-19-2009, 04:53 PM   #9
I just put vinyl sofit up on my pole barn. I nailed each piece to the 2x6 fascia board, then went back with the facisa metal and nailed it only from the bottom approximaetly every 3'. This helped to reduce the ripples in the aluminum. There are some, but the will be covered by the gutters.
On the gable ends, it is the same process, except for I had to put two nails in at the peak to ensure the pieces stay put.
If you nailed into the front of the fascia metal, as the temperature changes outside, the aluminium cant move with the wood and will really buckle and ripple up.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
More On This Topic
Learn how to bend metal roof shake tiles over the gable fascia in this free roofing instruction video. Read More »
Water damage can cause all kinds of problems for your home, but you can help prevent it if you buy the right type of fascia. While all types of fascia can function equally well, maintenance and cosmetic differences can help guide your decision. Read More »
Metal nail files are durable, widely available and simple to use. Using any type of nail file is easy, but there are a few things you need to remember while filing your nails to prevent them from cracking and breaking. Read More »
Fiber cement fascia boards provide the same water protection as other materials but offer increased options for finishes. Since fiber cement tends to be more expensive than other types of fascia, you need to take greater care when you install it. Read More »
Patching the aluminum siding on your home can be difficult because of how the panels interlock. It is possible to fix the siding with a little effort, some time and good weather. Read More »
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
Aluminum fascia wbeannn Building & Construction 6 11-07-2008 07:42 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing 10 02-11-2008 08:34 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
Where do I nail Aluminum Fascia? irlizard Roofing 5 08-05-2006 03:49 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
