Which Nailer To Buy - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-04-2008, 02:51 PM   #1
which nailer to buy
I am going to install a new roof on my shop, and am considering buying an air nailer. Sounds quicker and easier than a hammer right? I am looking at either a Bostitch U/RN46-1 or a DeWalt 51321 coil nailers. Any thoughts pro or con on either one? Also how do you figure how many coils of nails do you need /square of shingles?
thanks
alljays is offline   Reply With Quote
Old 06-04-2008, 03:19 PM   #2
Decide on your nailing pattern, see how many nails in a case of coils, check how many shingles per bundle and bundles per square for your roofing. Then you can decide how many cases of nails you'll need.
I got the Rigid coil roofing nailer, because it got good reviews and was cheaper than the Bostich. I've been very happy with it. Can do bump or sequential firing with the flip of a switch. (Probably doesn't matter for the pros, but occasionally when precision matters I like to turn off bump firing).
NateHanson is offline   Reply With Quote
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 12:17 PM
What kind of Nailer? Oldhouseowner Tools 15 02-15-2009 07:36 PM
2hp / 6gal Compressor w/ framing nailer scarrell Tools 4 04-24-2006 09:34 AM
What size nailer to use for Soffit Replacement Mach5 Roofing/Siding 2 01-28-2006 12:24 PM
