Nail Pops On Exterior Siding - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-01-2013, 06:45 PM   #1
member
nail pops on exterior siding
Siding on my house is like the 12 inch lap masonite siding, I have noticed on the
south and west side of my house that some of the nails have started to pop
out just slightly, some nails it just cracked the paint, others the nails have just started to pull away from the paint. I am getting ready to paint my house and I want to make sure that I make the correct repairs. Looking
for ideas on what works.
mcrannell is offline   Reply With Quote
Old 07-01-2013, 07:04 PM   #2
kwikfishron's Avatar
Rewards Points: 816
If the nails are popping then they probably didn't use ring shank nails and/or didn't hit the studs. It should be easy enough to remove those nails (without damaging the siding) and re-nail with ring shank siding nails into studs.
kwikfishron is online now   Reply With Quote
Old 07-01-2013, 09:41 PM   #3
member
pulled one nail out, I had to use a small pry bar with a piece of wood to pull the nail out, about 3/4 of the nail has spirals on it. Siding was put on my house about 15 years ago
Old 07-01-2013, 09:52 PM   #4
member
would you recommend putting a larger nail back in the same hole or nailing
above old nail hole with a new nail and filling old nail hole with some kind of
caulk, prime caulked hole then paint ?
Nail pops on very old sheetrock george5558 Drywall & Plaster 4 09-17-2012 08:26 PM
Strange bumps (not nail pops) on ceiling drywall davidarlington1 Drywall & Plaster 4 05-29-2012 04:43 PM
Drywall nail pops repair? ProudMarineDad Drywall & Plaster 1 06-23-2009 08:17 AM
How to Fix nail pops? iminvalid General DIY Discussions 9 08-08-2008 08:25 AM
nail pops nat Carpentry 3 11-11-2006 12:48 PM
