Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-11-2008, 06:00 PM   #1
Nail Count...
Just received a proposal for a new replacement asphalt roof. Likely using Tamko Heritage 50 year. Much of the roof is pretty steep (it's a Cape Cod style home located in suburban Chicago).
The proposal specifies 4 nails per shingle. I have no point of reference on this. Does this sound right?
thor is offline   Reply With Quote
Old 07-11-2008, 07:42 PM   #2
Doing This Way Too Long
Nail Count...
4 nails is the minimum for any shingle. Not sure on tamko's warranty but most require six-nailed for higher wind warranty. On a steep pitch with a 50 yr shingle, as a contractor, I would six-nail it anyways and I would recommend you request that of whoever is doing your roof. Then make sure they are.
OldNBroken is offline   Reply With Quote
Old 07-11-2008, 09:46 PM   #3
Super Moderator
Nail Count...
If your Cape Cod is a typical 12/12, then 4 nails per shingle are the stndard specification, but you had previously mentioned in another post that you lived right off of Route 53, so it depends on how much of a Wind Tunnel affect that travels over your home, if you are really close to the expessway.
Since you have considered it, why not suggest the 6-Nail per shingle pattern for the higher wind warranty.
The labor time is not much more and instead of getting 22 Squares out of each box of coil nails, they will get around 15 squares instead, so a little more charge for the extra nails should be added.
By the way, did you check out if they use Subs are use their own employees? Or, is that not a major consideration to you?
Just for interests sake, how many squares is your roof and how many layers are being torn off and what is the price spread between the guys you met with so far?
What happened to that guy who only did GAF shingles too?
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
Old 07-12-2008, 04:06 AM   #4
747
registered
747's Avatar
Nail Count...
I would go with the Tamko Heritage XL Ar over there 50 year shingle. Just because they have some sharp colors. Also i think 50 years is overkill. http://www.tamko.com/ProductDisplayT...1/Default.aspx
example black forest or slaystone grey or weathered stone. The XL is there 40 year shingle.
747 is offline   Reply With Quote
Old 07-12-2008, 11:53 AM   #5
Super Moderator
Nail Count...
I have never used the XL's because I think they look butt ugly.
Ed
Old 07-12-2008, 12:30 PM   #6
Nail Count...
OldNBroken, Ed, 747 - Thanks for the feedback. I actually went to the Tamko site on installation, so I could better understand Ed's comments. While I thought we had a really steep roof, I now have a better understanding of "really steep" (21" rise over a foot!). We're closer to the 12/12 that Ed mentioned. Thanks again.
Ed - The roofing contractor does his own asphalt, but has a sub for the cooper. I don't have some of the details you asked about the job size. There's one layer of roof being removed before replacement. This is the same contractor that mostly does GAF, but has done a few Tamko. That’s why one of my earlier posts asked if experienced roofers can reliably work across vendors. Thanks.
Old 07-12-2008, 08:23 PM   #7
Nail Count...
12/12 is still considered steep Thor. If I can't work on it without toeboards, we consider it a steep slope.
Old 07-13-2008, 12:49 AM   #8
747
registered
747's Avatar
Nail Count...
Ed
ACTually i have never seen them on a roof. I thought they looked good on there website. So i guess i would go with the 30 or 50 Year heritage AR in the color aged wood or natural timber.
Old 07-14-2008, 11:57 PM   #9
the roofing god's Avatar
Send a message via MSN to the roofing god
Nail Count...
12 on 12 requires 6 nails per shingle,and the XL`s are butt ugly !
"If it`s worth doing,It`s worth doing right!!"
the roofing god is offline   Reply With Quote
Old 07-15-2008, 01:50 AM   #10
Super Moderator
Nail Count...
I'll check again, but I think it requires 6 nails per shingle for a 16/12 and above. Not to say that that advise is not valid, but just what I remember the requirement being.
Ed
Old 07-15-2008, 06:12 AM   #11
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Nail Count...
Ed
They are =
- Build Well -
buying a nail gun with compressor Dave777 Tools 9 11-28-2011 12:37 AM
Nail Gun Plastic Nail Casing frustrations smark General Discussion 6 07-07-2008 09:10 PM
Best Practices for Framing Nail size jms5883 Remodeling 7 01-31-2008 12:37 PM
Using nail gun on deck fence? darsunt Carpentry 1 05-01-2007 09:11 AM
Nail Gun and Compressor - Help! MelindaA Carpentry 7 08-15-2006 09:17 AM
