My Roof Is Leaking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-09-2009, 03:27 PM   #1
my roof is leaking
I recently added a one story addition with a shed roof to a 2 story home. The roof ends at both corners of the house where the vertical vinyl runs up the corner. The contractor wrapped some kind of tape around it but it leaked. To fix the leak, he sealed the siding to the corner with clear caulk. This seems like a patch, how should it be done?
susanc is offline   Reply With Quote
Old 03-09-2009, 03:41 PM   #2
the Musigician
DangerMouse's Avatar
hi susan, welcome to the forum.
can you post a picture of what he did? it'd help a lot.
DM
Old 03-21-2009, 02:41 PM   #3
Post
Susans leaking addition
Its inproper flashing detail, with 30 years in building and construction trades I have become a troubleshooting expert. When tieing in to existing structure you need experience in the area of detail flashing and waterproofing. Ask a sheet metal flashing expert to look at the problem. . Have the flashing expert do the proper installation then have the flashing expert write a detailed explanation as to the problem then take it to your contractor for reinbursment of costs. There should be no doubt as to the liability of costs for the repairs. Have a great day!
NATRINO
NATRINO is offline   Reply With Quote
Old 03-21-2009, 03:40 PM   #4
Shingles? Metal? Might help if we knew what type of roofing. Step flashing with shingles and sidewall flashing with metal. Silicone and caulking is not the way to fix it. Get someone with some roofing know how to help you out.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 03-22-2009, 01:19 PM   #5
Leaking roof
When she said shed roof I took it as a flat roof and a hot system, torch down or granulated cap sheet.
Old 03-24-2009, 04:02 PM   #6
Wink
roof leaking
How did you notice the leak? Is there damage inside as well?
When a new roof joins an old wall and it leaks, there is a lot of damage that could be hidden. Besides just fixing the flashing, I would do a little investigating to see how much moisture got into the wall, etc. The contractor should also be liable for this damage repair too.
Future mold issues are just one concern, and further into the future rotting may occur. Something to watch out for!
harvster is offline   Reply With Quote
Old 03-25-2009, 01:00 PM   #7
Commercial Roofing
AaronB's Avatar
How did you come up with that out of the term shed roof?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-26-2009, 09:26 PM   #8
roof leaks
your problem most likely is flashing or counter flashing,post a picture for a detailed solution
fitzsm is offline   Reply With Quote
Old 04-12-2009, 01:15 PM   #9
Roofing Contractor
Leftyho's Avatar
Hi,
I have to hear that one to Aaron.
The old scare everyone with the mold response??
Roof coating to fix step flashing. Must be a painter.
Leftyho is offline   Reply With Quote
Old 04-13-2009, 01:40 PM   #10
Originally Posted by Leftyho View Post
Hi,
No Lefty, just a Spammer. He is gone now.
Ed
Ed the Roofer is offline   Reply With Quote
Tags
flashing for vinyl siding , leak in roof , shed roof
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 12:19 AM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 06:51 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
