Is My Ridge Vent Installed Correctly? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-02-2011, 10:40 AM   #1
FlyingHammer
Is my ridge vent installed correctly?
The attic space above my garage seems way too hot and I'm wondering how to tell if my ridge vent is installed properly. The attic floor is well insulated, and I can clearly see plenty of light coming through all the eave vents so I know they're not blocked. The only other variable seems to be the ridge vent, and I'm wondering if the roofer nailed it down too tight. Should I be able to see any light coming through it?
Any other suggestions to reduce the temperature up there?
Thank you in advance.
FlyingHammer is offline   Reply With Quote
Old 07-03-2011, 12:35 AM   #2
Registered User
Rewards Points: 4,888
http://www.inspectapedia.com/interiors/atticcond10.htm
http://www.airvent.com/homeowner/pro...it-specs.shtml
http://books.google.com/books?id=3kL...201991&f=false
http://www.fureyco.com/content/image...ng_The_Air.pdf
Gary
Old 07-03-2011, 03:56 PM   #3
AGWhitehouse's Avatar
If you find everything to be installed correctly you can check the temperature up there. You don't want it much hotter than 105F...
You can either install roof turbine vents (Passive exhaust fan), a motorized fan with thermostatic controller, or gable end louvers if you have a gable available.
AGWhitehouse is offline   Reply With Quote
Old 07-04-2011, 04:29 PM   #4
Be sure to check and see if ventilation is coming through your soffitt bc a lot of times insulation install will block this, this is why things called baffled are installed that fit between the insulation and underside part of roof to allow the air to pass.
roofie is offline   Reply With Quote
ridge vent vs. gable ceiling fan snarkk Roofing/Siding 1 09-22-2010 04:06 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
ridge vent ?'s Zel1 Roofing/Siding 6 05-19-2009 09:53 PM
Ridge vent installation cost Douche Roofing/Siding 1 07-26-2006 05:59 AM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 09:32 PM
