MY Gutters Nails Are Loose - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-17-2010, 09:50 AM   #16
Rewards Points: 101
@Yoyizit - I didn't measure , but I did notice my gutters slope towards the spouts.
JRMN is offline   Reply With Quote
Old 05-17-2010, 12:18 PM   #17
Originally Posted by seeyou View Post
Yikes - that would run off of the fascia on many houses if the fascia was indeed truly level. Usually, the fascia is out of level in the opposite direction of where you want the gutter to drain. 1/4" per foot is about the max necessary and that's seldom obtainable in real world conditions.
1/4" per foot is 10/4" per 10', 2-1/2" per 10'.
Old 05-17-2010, 12:25 PM   #18
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
OOPS - I meant 1/8" per foot and was reading your post as 1" per foot. Pretty much missed the boat on that one all the way around. Ignore me. Carry on.
seeyou is offline   Reply With Quote
Leaking Gutters fripster Roofing/Siding 5 02-13-2010 08:25 PM
Box Gutters Fix or Aluminum? jonathan03 Roofing/Siding 4 01-01-2009 12:42 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
Do I replace my gutters? nymark Roofing/Siding 5 06-18-2008 09:36 PM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 10:54 AM
