Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-10-2010, 10:27 AM   #1
MY Gutters Nails Are Loose
The other day I noticed the nails in my gutters are coming loose. I do have a 32’ extension ladder and I could go by Lowes or Home Depot and picking up some gutter screws. Since, I have quite a few gutters that need to be repaired, I am just wondering if should I pay someone to do this or should I do it myself?
Is there anything special that I need to know about?
JRMN is offline   Reply With Quote
Old 05-10-2010, 10:33 AM   #2
It was a dark and stormy
Yoyizit's Avatar
More than half the people who fall 32' survive, but many wish they hadn't. You'll hit the ground at 30 MPH, about the speed of a fast punch.
I'd get a safety harness, and get an assistant.
Harness or not, I just turned down a job similar to this. Too much risk for too little money.
Old 05-10-2010, 11:41 AM   #3
Thanks Yoyizit, my roof isn't that high up. I should have just said I had a ladder. I'm more concerned with messing my roof up.
Old 05-10-2010, 12:20 PM   #4
Commercial Roofing
AaronB's Avatar
If you feel and can be safe on a ladder, I recommend screws.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 05-10-2010, 12:22 PM   #5
Commercial Roofing
AaronB's Avatar
If I were to come out and do this for you, even for one man, a half a day, and a truck, I would have to charge you minimum $750.00. Probably looking more DIY from this point of view.
Old 05-10-2010, 12:51 PM   #6
Thanks Aaron, I think I will do it myself. I am not going to try to replace every nail, maybe just the ones on every end and one or two in the middle. And from then on out, replace them as needed.
Old 05-10-2010, 01:06 PM   #7
fabrk8r
fabrk8r's Avatar
I suggest checking the condition of your fascia board before starting to reattach the gutter. The existing fascia may be starting to rot and that may be why the spikes are loose.
If the fascia board is in satisfactory condition, then I recommend using gutter screws rather than spikes. The screws cost a little more and take a little longer to install, but they tend to stay in better than spikes.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 05-10-2010, 01:21 PM   #8
Gutter screws cost about $1 each...at Lowe's.
They come in a 10 pack, and includes the torx bit.
handy man88 is offline   Reply With Quote
Old 05-11-2010, 01:56 AM   #9
Commercial Roofing
AaronB's Avatar
You may not even need the $1 screws, depending on what type of hangar you have. Can you snap a pic and post it?
Old 05-11-2010, 09:16 AM   #10
Sorry no picture, but from the looks of things it's just nailed into the fascia board. Yesterday I was able to replace a few nails on the back gutters. I have to get back up there because my hand drill died on me. Good thing I did because at least a few nails were gone.
I also want to replace a few nails on the front of my house, but it's not going to be as easy because I don’t have enough room to work with. The gutters are at the corner of my house where the garage and steps meet. I tried getting at it from the top of my roof but the pitch is to steep.
Old 05-11-2010, 09:55 AM   #11
Yoyizit's Avatar
While you're at it check that the gutters slope 1" in 10' using a line and level. You may have to relocate 2/3rds of the spikes for this to happen.
When you're done, pour some water in one end and watch what happens to it, but don't get your hopes up.
Old 05-11-2010, 10:03 AM   #12
the Musigician
DangerMouse's Avatar
IF the nails hit the rafter ends, AND there's little or no rot, you might be able to replace the missing nails with LONGER screws that will get a better bite to the rafter ends. When I do my new gutters, I will absolutely use screws to mount them, as I read too many times about nails failing...
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 05-17-2010, 09:14 AM   #13
Yoyizit's Avatar
And even if you hit them, it's end grain. The nail has to go cross grain for gripping power.
Old 05-17-2010, 09:56 AM   #14
the Musigician
Too true.... but I said....
replace the missing nails with longer __SCREWS__ that will get a better bite to the rafter ends.
Personally, I could never figure out the whole "spiking into a 3/4" piece of pine fascia and expecting it to hold water/snow/ice weight!" I suppose it's a bit better if the spikes hit the rafter ends, but.... still. I'll either be screwing mine up there, or perhaps looking into other means of hanging them that are available now.
DM
Old 05-17-2010, 10:44 AM   #15
Shut in w/o Home
seeyou's Avatar
Yikes - that would run off of the fascia on many houses if the fascia was indeed truly level. Usually, the fascia is out of level in the opposite direction of where you want the gutter to drain. 1/4" per foot is about the max necessary and that's seldom obtainable in real world conditions.
seeyou is offline   Reply With Quote
Leaking Gutters fripster Roofing 5 02-13-2010 09:25 PM
Box Gutters Fix or Aluminum? jonathan03 Roofing 4 01-01-2009 01:42 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
Do I replace my gutters? nymark Roofing 5 06-18-2008 10:36 PM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 11:54 AM
