My Flat Roof Project-help! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-15-2010, 11:13 PM   #106
Rewards Points: 956
by the way this is the proposal they gave me
federer is offline   Reply With Quote
Old 10-15-2010, 11:19 PM   #107
I think its a good choice.
johnk is offline   Reply With Quote
Old 10-15-2010, 11:20 PM   #108
Rewards Points: 956
p { margin-bottom: 0in; }p.western { font-family: "Times New Roman",serif; font-size: 9pt; font-weight: bold; }p.cjk { font-size: 9pt; font-weight: bold; } We hereby propose to furnish all materials and perform all the labor necessary for the completion of:
The removal of the existing 1 layer shingled and flat roof from the house. Replace 3 sheets of plywood with CDX plywood. The installation of the following fiberglass shingles with 15 lb felt. The installation of pipe collars, aluminum apron flashing and chimney flashing. The installation of Ice and Water Guard in the valleys and on rear low-sloped roof. The installation of aluminum drip edge on the rake and gutter edges. The installation of Firestone #180 modified bitumen 12-year roofing material on flat roof. All material fastened per manufacturers requirements. Trash to be removed from jobsite. Nails are magnetically removed from the ground. The house and shrubs are protected to the best of our ability. Homeowner is responsible to ensure selection of material and colors are in compliance with their Homeowners Association requirements and in accordance with County codes. Firestone guarantees their product for a period of 12 years with proper maintenance and S&K Roofing, Siding and Windows, Inc. will provide quality workmanship with a 10-year warranty against leaks or defects in workmanship.
Types of Roofing Material:
____ CertainTeed XT 25 year fiberglass shingles .................................................. ............................................... $6,483.00
____ CertainTeed Landmark 30 year AR fiberglass shingles .................................................. ................................ $6,787.00
Shingle Color Choice (Standard Colors Only Required):_________________________________
All material is guaranteed to be as specified and the above work to be performed as stated for the sums above.
The following items are not included in contract price.
The replacement of rotten plywood found or installation of new plywood will be done at a cost of $2.50 per square foot.
The replacement of rotten 1 x 6 wood planks found will be done at a cost of $3.50 per linear foot.
(Please place a check next to your selection, leave blank if you do not want any options).
It Is Recommended That Proper Attic Ventilation Be Installed To Uphold The Manufacturers Warranty.
____ The installation of Ice and Water Guard on the 1st three feet from the gutter edge (with above work only) .... $54.00
____ The installation of Ice and Water Guard on the 1st six feet from the gutter edge (with above work only) ..... $108.00
IMPORTANT NOTES:
  • Protect your belongings in the attic, as sawdust will enter the attic during the process of shingle vent installation.
  • We will remove any items attached to the roof (i.e., satellite dishes; basketball nets; antennas) and they will NOT be reinstalled. We cannot re-install satellite dishes as they must be installed by a satellite TV contractor.
  • We will not remove or re-install gutter covers, screens or helmets. Please notify our office if you have a gutter cover system prior to commencement of work.
  • We will not be held responsible for existing skylights leaking, replacement is recommended.
  • We will not be held responsible for wicking brick or mortar.
  • All metal roofing material will exhibit some oil canning in direct angles of sunlight, copper is especially sensitive to this.
Quotation is valid for 10 days from date of proposal.
Signed Proposal, 1/3 Deposit and Pertinent Color and Option Selections Required for Scheduling
Balance Due Upon Completion
Old 10-19-2010, 11:20 PM   #109
Rewards Points: 956
i know noone cares anymore, but my new roof is coming on thursday!!! cant wait. will post pics, unless you guys dont want to see the before and after
Old 10-21-2010, 04:01 PM   #110
Thrasher
If we didn't want to see pics we wouldn't have made this thread 8 pages long.
Lulimet is offline   Reply With Quote
Old 10-21-2010, 09:32 PM   #111
Rewards Points: 956
lol i will post some before pics gimme a hour
Old 10-21-2010, 10:56 PM   #112
Rewards Points: 956
day before apocalpse
heres some pics from when they dropped off materials today. stay tuned for tomorrow when the real doo doo goes down!
Old 10-21-2010, 10:56 PM   #113
Rewards Points: 956
Old 10-21-2010, 10:58 PM   #114
Rewards Points: 956
Old 10-21-2010, 11:00 PM   #115
Rewards Points: 956
Old 10-22-2010, 09:00 PM   #116
Rewards Points: 956
what do you guys think?
Old 10-23-2010, 08:08 AM   #117
Thrasher
I thought you were going with ce3rtainteed shingles?
Or maybe they are for a different delivery.
Old 10-23-2010, 08:34 AM   #118
Rewards Points: 956
yea i got certainteed. pic includes seperate delivery
Old 10-26-2010, 08:02 AM   #119
Professtional Remodeler
Sorry did realize you already completed the project. I take my comment back.
valueremodeling is offline   Reply With Quote
Old 10-26-2010, 08:05 AM   #120
I think you are a little late for suggestions
Questions about flat roof repair-repalcement crhilton Roofing/Siding 5 08-21-2010 01:25 AM
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 12:12 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing/Siding 2 11-23-2008 10:31 AM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing/Siding 11 01-07-2008 08:41 AM
