Moving A Valley - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-28-2012, 04:24 PM   #1
RFN-4A-LVN
Roofmaster417's Avatar
Moving A Valley
The only thing I can come up with is to move the opening of the valley to meet the corner of the chimney.
This is a redeck with a 7/12 pitch.
That dead pocket will be impossible to keep water tight without moving the valley..What do you think ?
Obviously this isn't a Diy project but there are some fellow knowledgable pro's whom I respect your comments so that is why I am posting.
Moving A Valley-img_20120428_135820.jpg   Moving A Valley-img_20120428_135829.jpg   Moving A Valley-img_20120428_135840.jpg   Moving A Valley-img_20120428_135853.jpg
Roofmaster417 is offline   Reply With Quote
Old 04-28-2012, 04:49 PM   #2
Rewards Points: 12,790
Pictures are so close it's hard to say. Is that just a cricket on the high side of the chimney?
Looks like your going to just have to make it wider.
It also looks like there's no propper flashing on any of that chimmney.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Roofmaster417 (04-28-2012), tinner666 (04-28-2012)
Old 04-28-2012, 05:03 PM   #3
RFN-4A-LVN
I will be installing Counter on the chimney.For some reason it has a narrow cricket.Not a clue why.,As far as the framing I thought about using the existing just adding where it will meet the corner.
Old 04-28-2012, 05:03 PM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Yeah - that cricket was built by a carpenter, not a roofer. It's pointless the way it's built. Cut you a couple of new triangles that bring it all the way out to the corners.
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
Old 04-28-2012, 05:22 PM   #5
Rewards Points: 528
I take exception, I think it was a roofer trying to be a carpenter that made that cricket
framer52 is offline   Reply With Quote
Old 04-28-2012, 06:02 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 820
While completely ridiculous, it is more common that you would hope.
Old 04-28-2012, 11:05 PM   #7
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Widen the cricket as mentioned before. Extend the valleys 3-4" past the corner as per normally done.
tinner666 is offline   Reply With Quote
Old 04-28-2012, 11:39 PM   #8
Pro Slate Roofer
tinner666's Avatar
Here's what you really have though. Most likely, it was a cinderblock chimney. Later, somebody wrapped it with brick. That's why you see mortar at the roof line and the shakes disappear under the brick. When you redeck, the new boards, or plywood will go under the outer layer of brick.
Just flash it normally and hope the bottom course or two of brick doesn't pop off.
Old 04-29-2012, 09:43 AM   #9
old timer
It would be best to move the valley out to meet the corner. If that is not possible, it would not be too hard to solder a copper pan in that pocket to make it water tight.
dmc@RCR is offline   Reply With Quote
The Following User Says Thank You to dmc@RCR For This Useful Post:
Tom Struble (04-29-2012)
Old 04-29-2012, 10:08 AM   #10
Ravenworks's Avatar
Nice,prime example of doing it right !
Ravenworks is offline   Reply With Quote
Old 04-29-2012, 10:32 AM   #11
Rewards Points: 820
Nice work.
Problem is...how many roofer know how to braze copper/metal anymore.
Old 04-29-2012, 12:00 PM   #12
Ravenworks's Avatar
Originally Posted by Windows on Wash View Post
+1
Nice work.
True,I just seen a roof done by the "Copper Smiths" in Akron that was fabulous,
Old 05-01-2012, 08:11 AM   #13
Rewards Points: 125
Well that's a thing of beauty dmc, hate to think what it cost though.
On a related note, reading this thread got me to pondering my situation, two chimneys and no crickets, and years of goop added by previous owner(s) kinda tell me they need something. For the roofing mavens here, how big a deal would it be to fabricate and install said cricketry? Already did the Google thing, doesn't seem too bad but usually that's an indication I am missing something. What's the one big thing I oughta know, and the biggest mistake made when doing this? That should help narrow the parameters of my "Oooops!"
ThatDaveGuy is offline   Reply With Quote
Old 05-01-2012, 10:17 PM   #14
RFN-4A-LVN
I always recommend a cricket over a pan any day.,as long as the chimney is more than a couple feet from the ridge.
I decided the best modification for this cricket is to push the ridge line up the roof the distance the existing cricket is lacking from hitting the corners.Extend the valley to meet those corners.Pushing the ridge line will help maintain the 7/12 pitch.
Taking Tinners advice I am dropping the ridge line into the chimney about 10 degrees to assist with controlled flow.
Put some counter flashing on the chimney and feel confident with the installation.
If the negative degree fails Tinner will be coming to the Ozarks.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 34 09-15-2015 07:23 PM
Help with tricky valley wombosi Roofing/Siding 34 11-11-2011 09:22 AM
Need input on this open valley technique jogr Roofing/Siding 12 11-01-2011 07:49 AM
I&W around pipes and valley metal fastening diyroofer Roofing/Siding 0 09-12-2011 06:39 PM
Closed valley leak Atskodinski Roofing/Siding 12 04-14-2011 06:29 PM
