Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 09-28-2011, 07:50 PM   #1
Question
Mounting Item to Roof
Hey all,
I am new here and looking for some help. I am trying to figure out the best way to mount a seasonal item to my roof, without causing any leaking issues.
Pretty much just need to mount some Christmas lights on a custom frame on my roof. Weighs around 5-10 lbs total and about 11' W x 10' L.
Any Ideas?
03-GMC is offline   Reply With Quote
Old 09-28-2011, 10:31 PM   #2
RFN-4A-LVN
Roofmaster417's Avatar
I would use sand bags if the pitch was low enough.
Roofmaster417 is offline   Reply With Quote
Old 09-28-2011, 10:32 PM   #3
Yuuup
OhioHomeDoctor is offline   Reply With Quote
Old 09-29-2011, 08:14 AM   #4
Exterior Construction
Windows on Wash's Avatar
Originally Posted by 03-GMC View Post
Hey all,
Any Ideas?
+1 on sand bags.
Is it close to the edge of the roof or square in the middle?
You could mount some brackets in the fascia or rake boards but I do not like putting anything through the roof deck unless there is no other option available. If you have to go through the deck, have a roofer do it and make it a permanent bracket that can be utilized the next season and so on.
Old 10-03-2011, 11:04 PM   #5
Thanks for all the replies. The grade of the roof isn't all that steep.
Here is what I am working with. Probably kind of hard to judge in the dark but only picture I have at the moment. Sand bags was my first idea, but wasn't sure if there was a better way of doing it.
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 01:19 AM
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 01:12 AM
Roof mounting a pergola tutt00 Roofing/Siding 1 07-10-2010 02:52 PM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 06:48 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
