Mounting Block For FIber Cement Siding - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-01-2014, 03:44 PM   #1
Rewards Points: 790
Mounting Block for FIber Cement Siding
Hey all,
Do you typically use vinyl siding mounting blocks w/ fiber cement siding? Or do you do something different. I have an A/C box and a few other blocks currently on my steel sided house and didn't know what to use for fiber cement when I approach those areas.
Someone suggested using the PVC trim I'm using on windows and cut my own blocks.
cibula11 is offline   Reply With Quote
Old 07-01-2014, 07:20 PM   #2
Rewards Points: 14,312
Vinyl siding blocks will work, I'd add some window tape around the nailing fin.
You would need 5/4 X wider then what your trying to mount trim boards so it would stick out past the siding.
The ones you have now will most likely need to go. Aluminum siding does not stick out as far as Hardee.
Old 07-01-2014, 08:34 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
+1 on Vinyl blocks working well.
Old 07-03-2014, 08:16 AM   #4
Rewards Points: 790
So are you suggesting I install the vinyl block, flash with tape and trim with pvc like I would the windows?
Old 07-03-2014, 05:47 PM   #5
roofermann's Avatar
Rewards Points: 401
The block is the trim.
roofermann is offline   Reply With Quote
Old 07-07-2014, 10:22 AM   #6
Rewards Points: 790
What about for coaxial cables/satellite cables? Are mounting blocks used for these or are holes drilled through the siding and cables pulled through?
Old 07-07-2014, 12:16 PM   #7
roofermann's Avatar
Rewards Points: 401
Search "exterior cable grommet"
Installing LCD to cement block jho Concrete, Stone & Masonry 5 02-02-2013 03:14 PM
Best way to insulate the outside of cement block house? badyellowvette Insulation 2 09-23-2012 10:43 AM
Proper way to flash exisiting windows when installing new fiber cement siding, plus.. deminimis Carpentry 8 09-23-2010 09:55 PM
Best way to insulating a heated detached cement block garage Joe Nulph Building & Construction 1 03-06-2006 10:30 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
