Moss On Asbestos Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-03-2013, 04:14 PM   #1
Rewards Points: 664
Moss on asbestos shingles
I have green moss growing on my asbestos shingles. The house was built in the 1930s. What is the best way to get this stuff off without damaging the shingles? I tried a product from the Bayer Company for moss, and it turned it brown, but it still will not come off after I used a broom. I cannot actually step on the roof or I will break the shingles.
Also is there any coating or treatment I can or should use to treat the asbestos shingles to prolong their life?
crescere is offline   Reply With Quote
Old 06-03-2013, 04:24 PM   #2
Rewards Points: 14,026
If the roofs in that bad a shape I'd leave the moss on the roof. It's not doing the roof any harm.
Round Up will also kill the moss.
Old 06-03-2013, 04:55 PM   #3
Rewards Points: 664
The roof seems okay in that there are no leaks. The moss is caused by a large amount of trees in this neighborhood. I trimmed what is on my property, but this will be a continuing problem here. I have read that moss will grow, and damage the shingles by lifting them up. Plus it does not look good on an otherwise nice stately house.
Will roundup damage the shingles?
Old 06-03-2013, 07:05 PM   #4
Wet moss covered asbestos shingles are going to be as slippery as whale snot. No way I'd want to be up on that roof cleaning it.
There's companys that do nothing but clean roofs, I'd be checking into that.
Old 06-03-2013, 08:09 PM   #5
Rewards Points: 664
I would not let anyone walk on those shingles. I just want a reliable chemical that will not harm the shingles and kill the moss so I can brush it off with a long handle broom while I stand on a ladder.
Old 06-03-2013, 08:34 PM   #6
Roofmaster
Rewards Points: 2,210
Those are probably the original roof shingles and they are asbestos. That is a real tribute to AB as a building material. Frankly Id leave the moss alone, thats probably keeping the water out, and it is a "green" encapsulant. Kill the moss and broom it, and you could make it friable. Id leave the moss and tear it off as a unit. Frankly the old felt under the AB is probably the only thing keeping you and the weather from coming together at this point.
Old 06-03-2013, 08:54 PM   #7
Rewards Points: 664
The entire roof is not covered in moss. Only the part near trees has moss on it. I was hoping someone knew of a chemical I could use that actually worked, but did not harm the shingle. What about bleach?
Old 06-03-2013, 11:14 PM   #8
Dave Sal's Avatar
Rewards Points: 728
I haven't used this myself but Bayer products seem to work well, even if they may take awhile.
Dave Sal is offline   Reply With Quote
Old 06-03-2013, 11:23 PM   #9
Doing This Way Too Long
Rewards Points: 532
Don't know what to tell you to use as moss and algae are regional issues but I can tell you do NOT use bleach.
OldNBroken is offline   Reply With Quote
Old 06-04-2013, 08:57 AM   #10
Roofmaster
Can you post some pictures of this roof? Id really like to see it if it is 77 YO and holdin. Im sure ONB would be interested too.
Old 06-04-2013, 04:10 PM   #11
Lord of Slums
Rewards Points: 1,974
same problem on friends house three companies cam out and told him he needed a new roof. The fourth guy sprayed something on the roof and the moss turned brown. The guy told me moss is difficult to remove and that my friend is just throwing his money away.
mj12 is offline   Reply With Quote
Old 06-04-2013, 06:16 PM   #12
Rewards Points: 664
I did use that, and it turned the moss brown, but the moss did not come off.
Old 06-04-2013, 06:38 PM   #13
Rewards Points: 664
Why? What is is the bleach will do to the shingles?
Old 06-04-2013, 08:00 PM   #14
Rewards Points: 532
Chlorine is a corrosive agent. Granted it is on the milder side, but still corrosive. Also it will not get to the "root" of your problem. Bleach is good for killing and neutralizing surface organics but little else.
Old 06-04-2013, 09:22 PM   #15
Rewards Points: 664
The root of the problem would be the trees, but they are not on my property so cutting them down is not possible. I am concerned that as the moss grows it will push up the shingles that are now not leaking. I did a Google search and there is a company that sells a product called D/2 Biological Solution which is supposed to be gentle on surfaces. I welcome any other suggestions.
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 07:50 PM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
Fastening something to asbestos shingles troyce1 General DIY Discussions 2 07-05-2009 02:39 PM
Adding stove top vent - cutting asbestos shingles t_mccann Building & Construction 6 11-29-2007 03:59 PM
Masonry Asbestos Shingles, how do I know? ourzoo Building & Construction 8 08-27-2007 08:57 AM
