More Of The Roofing Project Online - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-01-2006, 04:01 PM   #1
More of the roofing project online
Hi Folks,
I did another section of the roof this past weekend, and the pictures are online at:
http://www.AntlerProperties.com/roof.html
Look in section #2 for the update.
Thanks for the discussion from the first installment!
Responses to feedback from the other posting:
- The lower drip edge (at the gutterboard) *is* under the felt paper.
- The rake drip edge is over the paper - I took a better photo this time.
I have a questions about the flashing from the first section...the book I have shows leaving the nail exposed from the underlying shingle. Something about allowing the self-seal strip to contact the shingle above it. So here are the questions:
- Should I go back and put a dollop of sealant on each nail head for each section I have done.
- Should I nail higher up above the seal strip or allow the flashing to come lower down?
Thanks for the input!!
TomC
TomC (Md) is offline   Reply With Quote
Old 05-01-2006, 04:52 PM   #2
Commercial Roofing
AaronB's Avatar
Install the lower edge of the step flashing flush with the lower edge of the shingle, nail in the customary spot. This will leave your nailhead covered.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 05-01-2006, 05:03 PM   #3
Commercial Roofing
AaronB's Avatar
Your valley metal is nowhere near wide enough. You will probably have issues here.
Old 05-01-2006, 05:30 PM   #4
MJW
I would have just weaved them through in the saddle and used a big piece of flashing up the wall at that point. It would be probably easier to cut your edge as you go. It would be much faster.
I hope you are not anywhere near a high wind area.
MJW is offline   Reply With Quote
Old 05-01-2006, 06:50 PM   #5
Rewards Points: 150
It looks like job security to me. this will have to be redone in a few years by the looks of it.
RooferJim
RooferJim is offline   Reply With Quote
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 06:48 PM
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 05:32 PM
Roofing project online TomC (Md) Roofing/Siding 29 05-04-2006 10:09 PM
