More Ridge Vent Than Soffit: Good/Bad? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-31-2008, 01:42 PM   #1
Location: 100 miles north of Atlanta, 20 south of Chattanooga
More ridge vent than soffit: Good/Bad?
I am venting dormers with ridge vent and Smart vent.
I can get 72 to 90 sq in intake, and up to 126 sq in exhaust.
This total greatly exceeds 1/150 requirements(4x9 area), so ok there.
My question is, should I reduce the exhaust to equal the intake,
or is it better to maximize the exhaust even though it exceeds intake as
mentioned above?
Thanks in advance, and have a safe day.
Alan
oldgrunt is offline   Reply With Quote
Old 12-31-2008, 02:38 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
i was told you should have more intake then exaust i think it 2/3 intake 1/3 exaust im assuming it has to do with air pressure and proper air flow
Tom Struble is offline   Reply With Quote
Old 12-31-2008, 02:43 PM   #3
Funny. I thought exhaust area should be larger than intake on non fan assisted ventilation. Must check buildingscience.com on this.
sawyerEd is offline   Reply With Quote
Old 12-31-2008, 03:55 PM   #4
Joe Lstirubek himself claims that he would prefer all soffit ventilation instead of all exhaust ventilation, given that as the only option.
A 60% Intake to 40% Exhaust is the most desirable.
With such a small area, it shouldn't present a problem for the OP's case though.
Ed
Ed the Roofer is offline   Reply With Quote
Old 01-01-2009, 02:01 PM   #5
the roofing god's Avatar
Send a message via MSN to the roofing god
most mfgr`s quote "balanced ventilation",which would infer they be the same--little extra exhaust won`t hurt though,just don`t run other vents that would effect the cross ventilation(bottom to top) function
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Ridge Vent > Gable Vent jelly Roofing/Siding 10 06-09-2008 08:30 AM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 04:22 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-22-2008 12:35 AM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 05-01-2007 12:14 AM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 09:32 PM
