Mold In The Attic... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-25-2012, 08:22 PM   #16
Registered User
Rewards Points: 4,924
Yep, it doesn't take much to confuse me anymore.... pictures would help. Is there any air pathway from the ducting (along it's length) to the sheathing in the attic where the mold is?
Gary
Old 11-25-2012, 08:39 PM   #17
Rewards Points: 45
Gary
I agree pictures are always good. I'm working right now so the pictures I have below are all I have for today. I can take more tomorrow. One picture is an exterior side view of the boiler room. The other picture is inside of the boiler room. Where I took the picture is where the tubing for the dryer crosses. It's no where's near the sheathing in that room, maybe 5-6 ft away from it. And it's not even close to the sheathing in the attic that has mold. But what I pictured is where the heat transfer from the boiler room to the attic, the area in the attic where the mold is growing.
Side note: the boiler room doesn't have mold on the roof sheathing of that particular room.
noodle9400 is offline   Reply With Quote
Old 11-26-2012, 10:51 PM   #18
Registered User
Is the warm, moist air from the boiler wetting the sheathing? Are they in-line? You need to air-seal the drywall on the walls/ceiling (and insulate) to stop the diffusion or possible air channel leak which is causing the condensation on the first-condensing-surface it reaches: http://www.buildingscience.com/docum...bout-diffusion
ADA the drywall: http://www.buildingscience.com/docum...wall-approach/
Stop the air leaks between spaces: Figs. 1-4: http://www.buildingscience.com/docum...apor-retarders
Gary
Old 11-27-2012, 05:53 PM   #19
Rewards Points: 45
Gary
In the boiler room, not that I am aware of. I haven't seem any condensation drips or anything from that room. Only in the attic near that room where I recently closed off access. I have insulation in that area of the attic. I'd say 90% of the attic has unfaced insulation laying on top of very very old faced insulation. I did that because the owner of SeaShore Construction company told me to do so.
I noticed today that those 4 joists that I closed up, are not the only ones that could transfer air. However, the 4 I closed up in that section is the area where mold is growing. I hate this house.
Curious question: Do they make a paper based vapor retardant? Like the paper that's on faced insulation? I asked because I have that unfaced insulation up there but maybe the faced insulation underneath should've just been replaced altogether.
Old 11-27-2012, 10:45 PM   #20
Registered User
There is asphalt coated paper faced batt. The moisture is coming from somewhere directly below the area. Check for a bath fan duct with a hole, dryer duct hole, gas appliance exhaust ducting hole = excessive moisture. It has to somewhere, don't give up! Use a rake to remove some insulation over the exterior wall under the moldy area. Wiring hole through the top plate running down to the crawlspace/basement with moisture rising on the "stack effect"; http://www.wag-aic.org/1999/WAG_99_baker.pdf
Here, I'll help you look: http://www.finehomebuilding.com/PDF/Free/021105092.pdf lol.
If that back entrance is heated (how, what type), it could be melting the roof snow, but not the moisture issue.
Gary
Old 11-28-2012, 10:54 AM   #21
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Gary
Insulation is one solution, ventilation is the other. If the room were un-used for anything other than a boiler, wouldn't it be more simple and effective to install some adequate breather ventilation and just evacuate that moist hot air, rather than trapping it inside?
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 11-28-2012, 08:33 PM   #22
Registered User
Ventilation is fine but I'd find the source of the moisture first...if it is that room. Look at the water stains on the inside roof sheathing. I suspect their is no air supply to the boiler, is it gas fueled (note the "B" vent above on exterior pics)? Does it have air supplied high and low or is it required (H2O by-product of combustion)? Still checking if solid blocking between boiler room and house attic. Help find the source, then add venting after air sealing (localizing) it, would be my plan of attack, your thoughts?
Gary
Old 11-30-2012, 01:23 AM   #23
Rewards Points: 45
That is a good idea. Never thought of that before. However, come spring time I plan on replacing the roof on the boiler room and the roof on the room with the metal heat exchange and sealing off the attic to that area of the house.
Gary
Well based on visual appearance of the roof during snow storms and where the mold is in the attic, it is clear that moist air is getting to that area from that room. In the boiler room it does look like there was a severe water leak at some point in that rooms life between the walls and the sheathing. I do know the sheathing wasn't really replaced when I had the roof redone in 2010. They just put knew sheathing on top of the old. The boiler does reside in a room with open access to the crawlspace. No real ventilation in that room, at least none on the roof of that room. It is a gas boiler. The way it looks the vent piping for the boiler has condensation that falls back down to the boiler with a pump connected to it. Now the my boiler is running, ill check to see the sheathing in that room has any type of condensation. But as stated before I do plan on redoing that particular roof in spring. When I do I will seal all connections to the attic and ventilate that room somehow. Not sure how yet.
Mold problem after unfinished house was closed in for the winter... lemonbltz Building & Construction 28 12-30-2011 08:52 PM
Attic mold? venting into attic? therompster HVAC 4 06-03-2011 07:18 PM
Attic Mold Rhizando General DIY Discussions 20 03-19-2011 09:07 PM
Attic Mold - Correct Ventilatoin michelle239 Roofing/Siding 3 03-02-2011 05:49 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
