Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-26-2012, 11:14 AM   #1
Mold in attic
Sorry if this isn't posted in the right forum. It's arguably a ventilation issue as much as roofing.
I have some mold in my attic up along the rafters. I could spray it with something maybe a mixture of bleach and water but I don't know if it'll help much. I used to have the bath vent just going into the attic, but I corrected that ducting it to the outside.
I only have 2 gable vents and a solar attic fan. Should I be calling in a mold remediation contractor or could I treat this myself?
strategery is offline   Reply With Quote
Old 10-26-2012, 02:59 PM   #2
Mold in attic
Need more info.
Got any soffit vents? Without them the roof vents are not doing much.
If there is soffit vents are they blocked up with insulation?
Has the attic been air sealed? (sealing up any place like wiring, plumbing, light and ceiling fans where air can get into the attic.
May be far better off getting rid of your other vents and just having a ridge vent so the whole roof gets vented not just the ends and circles where the solor vents are.
Old 10-26-2012, 03:04 PM   #3
Mold in attic
Treat the mold with a product like Timbor or Boracare.
Going to have to buy it on line most likly.
Old 10-26-2012, 05:59 PM   #4
Mold in attic
Originally Posted by joecaption View Post
Need more info.
I've had half a dozen people tell me that I can't put soffit vents in the type of roof I have. The rafter tails stick out under the eaves. I already tried going this route.
I just have two gable end vents and the solar attic fan up top. Maybe I could enlarge the two gable end vents for more intake ventilation? It's a small roof and a small house.
Old 10-26-2012, 07:34 PM   #5
Pro
Mold in attic
Venting at the top of your roof is exhaust. If you don't have any intake at the bottom, the air down there will stagnate. You CAN get ventilated drip edge. You'll have to remove roofing at the bottom edge, cut the decking back a little bit, install the vented drip edge, then put roofing back.
http://www.airvent.com/homeowner/pro...ventedDE.shtml
smalpierre is offline   Reply With Quote
Old 10-26-2012, 07:36 PM   #6
Mold in attic
Need to post a picture.
No reason in most cases why you could not just add 3 or 4" round snap in vents in the boards that are used for blocking between the rafters.
Old 10-26-2012, 08:17 PM   #7
Super Moderator
Mold in attic
Post a picture of the roof over hang--there are a number of different vents for that style of roof overhang---
most are easily done by a homeowner or could be hired out at a fair price.
Mold problem after unfinished house was closed in for the winter... lemonbltz Building & Construction 28 12-30-2011 08:52 PM
Attic mold? venting into attic? therompster HVAC 4 06-03-2011 07:18 PM
Attic Mold Rhizando General Discussion 20 03-19-2011 09:07 PM
Attic Mold - Correct Ventilatoin michelle239 Roofing 3 03-02-2011 05:49 PM
Attic Ventilation Question handy man88 Roofing 10 02-12-2010 11:50 PM
