Mold In The Attic - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-11-2012, 10:37 AM   #1
Mold in the attic
I own an old stucco tudor and recently had an insulation contractor over to insulate my attic and walls. While up in the attic (we only store a few things and rarely go up there) the contractor noticed black mold. He stated that it was caused by lack of airflow because of venting issues. I now have to have the mold remediated which essentially blows my budget for the insulation I planned on having blown in. The roof was replaced just prior to us buying the house 3 years ago.
If I can find out who installed the roof wouldn't they be liable for the remediation and any other related expenses?
Any advice would be greatly appreciated.
Matt3719 is offline   Reply With Quote
Old 07-11-2012, 10:46 AM   #2
Rewards Points: 13,752
Nope, they were hired to put a new roof on not reverce engineer a poor roof design.
Killing the mold will only be a small part of what is need to fix the real problum.
Post some pictures of the outside of the house.
Tell us if you have any roof venting and what type.
Is there working soffit vents that are not all covered up with insulation?
Not a big deal to get that mold treated in most cases. Any exterminator can just spray on some Timbor, or Boracare or any number of other products that will kill the mold and stop it from growing. No need for a haz mat team.
DO NOT TRY JUST SPRAYING IT WITH BLEACH!
CopperClad (07-11-2012)
Old 07-11-2012, 10:47 AM   #3
Hello, and welcome to DIY. First thing is, you say the "HE" noticed mold. Did you actually physically see the mold? Thing is, there are a lot of wonderful, truthful, and honest contractors out there.. Then there are some that will tell you anything to make a quick buck. I'm not telling you the contractor you had out was a liar of anything... but anytime you decide to do a project on your home, get a minimum 3 estimates. Minimum 3 different opinions and corrective action to fix the problem if there is one. He said you have ventilation issues? What kind of issues? Talk about that with us. No soffit vents? No ridge vents? What kind of lack of ventilation is there? We can help, just a little detective work will need to be done. Good luck !
CopperClad is offline   Reply With Quote
Old 07-11-2012, 09:31 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,786
No.
As stated previously, the roofer was hired to replace the roof and unless you can prove negligence because they modified the venting, you have no cause either.
Mold is a tricky subject mater as well because I could likely make the case that leaking stucco created the interstitial moisture issue that lead to the attic humidity and so on and so on.
How bad is the mold? Post up a picture.
Have you had it tested? It is relatively cheap it will tell you what type and what type of remediation is required. If it is not toxic mold, most aren't, you can kill it yourself and fix the venting on the roof.
Problem solved.
The Following User Says Thank You to Windows on Wash For This Useful Post:
d0hboy (02-14-2014)
Mold problem after unfinished house was closed in for the winter... lemonbltz Building & Construction 28 12-30-2011 07:52 PM
Attic mold? venting into attic? therompster HVAC 4 06-03-2011 06:18 PM
Attic Mold Rhizando General DIY Discussions 20 03-19-2011 08:07 PM
Attic Mold - Correct Ventilatoin michelle239 Roofing/Siding 3 03-02-2011 04:49 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
