Moisture In My Attic - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-24-2009, 08:34 AM   #1
moisture in my attic
hi- i just had a new roof put on & reinsulated my attic. this winter i have leaks in my drop ceiling in 1 bedroom & tha bathroom. my contractor tells me its condensation because its been so cold & that because i have a drop ceiling, i'm loosing heat. anyone know if thers any fixes for this? he says the only way to fix it is to put up sheet rock
mnalberti is offline   Reply With Quote
Old 01-24-2009, 09:35 AM   #2
Remodeling Contractor
What type of attic ventilation do you have. And escaping moisture in your attic should be vented. When they installed the new roof, did they add a ridge vent. One fix you can do easily is add a powered attic vent.
Old 01-24-2009, 10:34 AM   #3
moisture in attic
they did install a roof vent- the 1 contractor actually went up and said there's enough circulation of air. so i'm baffelled
Old 01-24-2009, 01:58 PM   #4
do you have a vapor barrier on top of this dropped ceiling and under the attic insulation?
Old 01-25-2009, 03:33 AM   #5
the roofing god's Avatar
Send a message via MSN to the roofing god
any new insulation installed needee to be unfaced,or there would be condensation problems from that,and do you have an exterior exhaust vent for the bathroom fan,that happens all the time with bathrooms that don`t have the external exhaust because the fan is just dumping hot air into the attic,where it condenses against the plywood
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 01-26-2009, 10:07 AM   #6
codnesation
the first original insulation was papered- they put that on the drop ceiling for the vapor barrier. the new insulation that i added was unfaced.
for the bathroom ventilation i have just a regular fan in the bathroom. the original owner of the house never installed a bathroom fan. so, no exhaust is going into the attic. part of the leak is also in 1 of the bedrooms-
Old 01-29-2009, 12:04 PM   #7
Grumpy's Avatar
Rewards Points: 524
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
ATTIC VENTILATION IS A SCIENCE THAT IS UNIQUE TO EACH BUILDING. THERE IS NO ONE SIZE FITS ALL SOLUNTION. Please provide a picture of your house and aproximate square footage. What type of ventilation do you currently have? Do you have an intake? Did they overinsulate and block the intake? What type of ventilation did you have before the new roof? Did you actually change out the old insulation or install new over old? What is the new R value? What city is the building in? Do you have kitchen and/or bathroom fans, if so where do they vent? What % is your humidistat set at on your furnace? Do you use humidifiers in your house?
No advice can be considered sound until we have these details. For example I wouldn't usually ridge vent a hip style roof, and definetly wouldn't ridge vent if there were no intake. Also I wouldn't mix an attic fan with a ridge vent as this is a big no no, and can actually cause more harm than good.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 01-29-2009, 12:07 PM   #8
Grumpy's Avatar
Rewards Points: 524
Justa follow up, you said you added a fan. Where does it ventiate? INTO the attic? That's bad, very very bad. Does it physically have a hose or duct of some kind connecting the fan to a dedicated baffled exhaust vent? Not a typical mushroom vent, but a baffled kitchen or bathroom vent. This might be a major contributor to your problem. Please answer some of my questions above and I'll see if I can offer any help.
One other question, how did the contractor determine there was good air flow, and was the attic hatch open at that time? If the attic hatch was opened, you actually create a wind tunnel and there is a major movement of air from the inside into the attic and it makes it appear there is great air flow, when indeed you don't know for sure until you close the hatch cover. And finally he could just be lyeing to you to cover his butt
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Attic moisture Carstonio Roofing/Siding 14 01-29-2009 11:35 AM
No Moisture Barriers 1parkpointer Roofing/Siding 4 12-11-2008 06:44 PM
Question about attic moisture Mastershredder Roofing/Siding 3 03-19-2007 04:32 PM
