Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-17-2009, 05:45 PM   #1
Modified roll roofing problems
Ok, so here is the deal i live in the desert southwest Las Cruces NM and what i keep running into is modified roll roofing that is cracking. Most of the cases that I have run into are newer roofs 2-5 years old that look like they are about 7-10 the granuals are cracked into small cracks but only on certain sections of the roofing material. Its driving me crazy cause i know that this cannot be normal i just cannot figure out why this is happening or what to do about it.
chilltrain1 is offline   Reply With Quote
Old 04-17-2009, 06:04 PM   #2
Cracked anywhere or only where the material is bent say around an edge?
Roll roofing will crack if bent sharply or if bent at low temperatures such as on a cold and frosty morning.
Alternatively it might simply be shoddy material.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 04-17-2009, 10:15 PM   #3
Super Moderator
Why are you running into so many roofs?
Are you a roofing contractor or inspector or something else?
What brand markings might you have stumbled upon during your inspections?
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
Old 04-19-2009, 09:31 AM   #4
Hey guys,
I am a contractor here in the city and i do roof inspections from time to time, the cracks are on both the parapet walls on on the flat unbent field of the roof! But here is the really wierd part they occour sometimes on only sections of the same sheet of roll roof! THe most common brands of material used here is GAF and TAMKO we see some OWENS CORNING but not much its too expensive for most.
Old 04-19-2009, 04:08 PM   #5
Super Moderator
Where is "Here In The City?"
Could you fill in your profile. It sometimes makes a difference on the advice.
Also, do you have any photos that you can upload?
Ed
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing 9 09-13-2009 06:32 PM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing 5 01-06-2009 07:51 AM
Modified Bitumen or roll roofing Ricardo Roofing 7 05-08-2008 07:38 AM
Roll roofing material RedDawg454 Roofing 8 05-03-2007 07:52 AM
Roofing Contractor Problems lken1 Roofing 3 08-11-2005 08:58 AM
