Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-07-2008, 10:15 PM   #1
Modified Bitumen or roll roofing
Hey there
I'm having trouble understanding the difference between Modified Bit roofing and roll roofing. I understand that they can look similar but are very different life expectancy and durability.
Any offers?
Ricardo
Ricardo is offline   Reply With Quote
Old 05-07-2008, 10:56 PM   #2
the roofing god's Avatar
Send a message via MSN to the roofing god
ROLL IS TYPICALLY PAPER BASE SATURATED WITH TAR WITH CERAMIC GRANULES IMPLANTED ON IT,NEEDS TO BE TARRED IN PLACE--rating1
modified bitumen has a polyester base,asaturated with tar and rubber additiveswith smooth or ceramic granule finish,can be tarred down,or better yet flame welded at seams to make it as one piece of roofing when complete rating 10
"If it`s worth doing,It`s worth doing right!!"
the roofing god is offline   Reply With Quote
Old 05-07-2008, 11:39 PM   #3
Roofing God
Thanks for that. Guess my problem is I'm looking to buy this place with a flat roof over a sunroom 3 in. in 10 ft slope. Metal edge flashing.The roofing lengths are roughly 36 in wide with 3 inch overlapped. No seams showing through below this covering. Grey granules, no tar residue except for slight bit at some seams. Actually looks a bit patched together in places. At least its well enough sealed down that I can't peel up a corner to get a look at it.
I'm at a loss, cause I know roll roofing only is good for a few years.
Ricardo
Old 05-07-2008, 11:44 PM   #4
post pics,it sounds like modified bitumen,which can give you 10-20 years or longer
rolll roofing(90#)can be torn by hand but not the mod. bit.
Old 05-08-2008, 12:32 AM   #5
Super Moderator
Some laymen erroneously call Modified Bitumen, "Roll Roofing", since it does come in a roll, but the more accepted definition of "Roll Roofing" is the cheap 90 # granulated material, just as TRG has already stated.
You would be able to easily grab a corner and pull it apart, but not so with the Mod Bit membrane.
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
Old 05-08-2008, 12:37 AM   #6
Roofing God
Ya, no pics of the roof, but what you've described, it must be mod Bit. I know people do dumb ka ka sometimes, but it would have been a lot of work to install this for 5 or so years of service. Didn't mention that 4 skylights involved as well.
If I can nab a photo tomorrow I'll post it.
Thanks so much for your input.
Cheers
Ricardo
Old 05-08-2008, 12:42 AM   #7
Ed
Ta for that bit.
Yes, I couldn't grab anything to have a look see. The thing that troubled me was that the surface looked so similar to rolled roofing which I am familiar with.
Thanks ED
Old 05-08-2008, 07:38 AM   #8
Ed,
Throw up a couple pics of my roof so he can see why to not go with the rolled roofing.
Bob from Elgin
BobA is offline   Reply With Quote
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing 9 09-13-2009 06:32 PM
EPDM vs Modified Bitumen for flat roof arubatan Roofing 16 11-19-2008 07:50 AM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing 11 01-07-2008 09:41 AM
Roll roofing material RedDawg454 Roofing 8 05-03-2007 07:52 AM
Tar & Gravel vs. Modified Bitumen ($13k or $7k) ?? Roscoe Roofing 6 10-10-2006 09:34 AM
