Modified Bitumen Repair - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-11-2009, 08:08 AM   #1
Having an issue with water leaking in around a water supply pipe that comes up through the roof. Any advice on the appropriate sealant to use to repair would be appreciated.
medge is offline   Reply With Quote
Old 07-11-2009, 12:19 PM   #2
Residential Roofer
Slyfox's Avatar
Depends on why/how it's leaking.
New roof, poorly flashing detail?
Old roof, properly flashed and simply worn out?
Leaking at the base through the roofing material,
or leaking higher up on the metal/lead flashing covering?
If it's an old roof leaking at the base, roof cement and cotton mesh properly installed around the penetration can last years.
If it's leaking from the pipe detail above roof level than some metal caulking spread around the pipe flashing could be your fix.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 07-11-2009, 02:16 PM   #3
Also, what type of roof?
Flat, Shingle, Metal, Tile, etc...
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-11-2009, 06:22 PM   #4
Angry
It's a flat roof. My son just sent me pictures and it looks like the plumber who came out to fix the water leak (in the faucet) pulled the pipe up through the roof and broke the original seal around the pipe. So now he does not have a leaky faucet but his roof leaks when it rains. Is it ok to use a siliconized caulk to seal around the pipe until he can get a qualified roofer to come out and do a more permanent fix?
Old 07-11-2009, 06:25 PM   #5
Sorry, left out the answer to your second question. It's a modified bitumen roof.
Old 07-11-2009, 08:39 PM   #6
Yes, you can use caulk as a temporary repair.
The proper way to patch a pipe penetration is with a "Target Patch", so that when you cal up any roofers, you know what to tell them you need. There is a little more to it than just that term, but at least they will know what they are being called out for.
Ed
Old 07-12-2009, 06:22 AM   #7
Thanks Ed. I appreciate the help!
Old 07-16-2009, 09:44 PM   #8
Bitumen roofs are very delicate. Goooood question. These roofs are notorious for off-gasing during hot weather. This causes heavy expansion and shrinkage. The simple solution is to contact your local roofing supply specialist and purchase anti-off gasing spray. This can be applied by any do-it-yourselfer with a simple garden weed sprayer. The cost savings is ASTRONOMICAL compared to what a contractor will charge.
Good luck,
lawnmowererepairguy
mowerrepairguy is offline   Reply With Quote
Old 07-16-2009, 10:46 PM   #9
Good luck,
lawnmowererepairguy
Ignore the man behind the curtain.
Ed
EPDM vs Modified Bitumen for flat roof arubatan Roofing/Siding 16 11-19-2008 06:50 AM
Modified Bitumen or roll roofing Ricardo Roofing/Siding 7 05-08-2008 06:38 AM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing/Siding 11 01-07-2008 08:41 AM
Tar & Gravel vs. Modified Bitumen ($13k or $7k) ?? Roscoe Roofing/Siding 6 10-10-2006 08:34 AM
Adding granules to smooth modified bitumen KCnorthernCA Roofing/Siding 7 06-22-2006 05:25 PM
