Mod. Bit Over Edpm Rubber ?? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-01-2012, 01:16 PM   #1
Mod. Bit over edpm rubber ??
Has anyone ever put a layer of self adhesive Mod. Bit. such as Liberty roofing over existing epdm rubber? Thinking of doing it in a small flat area @ end of addition roof to help eliminate ponding (maybe?) and buy some time before complete new epdm rubber is installed over tapered iso board. Wondering if the Liberty will adhere to the epdm? Any thoughts or experiences would be appreciated.
gordieax is offline   Reply With Quote
Old 06-01-2012, 02:52 PM   #2
I know alittle about alot
JWilliams850's Avatar
how would that temporary eliminate ponding? you're just installing another material over existing? why not just do it right the first time? tear off get some taper iso and new roof?
JWilliams850 is offline   Reply With Quote
Old 06-01-2012, 06:51 PM   #3
Mod. Bit. over epdm rubber
Thanks for the reply, JWilliams 850. I agree the right way to do it is w/ tapered iso board and that's my plan , long term. As the attached photo hopefully shows, the current epdm is in good shape and in only ponds near the far end. I figured if I added a layer of mod. bit Liberty where it ponds it would raise the surface enough to eliminate the belly/depression in that 3" area and allow the water to carry over the end gravel cleat. No?
Old 06-02-2012, 05:09 PM   #4
Doing This Way Too Long
Rewards Points: 532
No it won't eliminate the ponding and...
No you can't adhere it to epdm
OldNBroken is offline   Reply With Quote
Old 06-02-2012, 06:24 PM   #5
Mod. Bit over epdm rubber??
Thanks. That's just what I needed to know. Guess I gotta bite the bullet and do the whole job, tear off, new tapered iso and new epdm rubber. Ouch! Things are seldom easy.
rubber hoses - code compliant? daixloxbmw Plumbing 10 01-07-2011 08:15 AM
Rubber Roof Sealant ninghai Roofing/Siding 17 03-08-2010 08:58 PM
rubber coating for paved backyard hellomoto Landscaping & Lawn Care 3 10-18-2009 10:09 AM
Help with repairing a flat rubber garage roof Toasty Roofing/Siding 2 07-01-2008 08:43 AM
Rubber roof prices tgf40 Roofing/Siding 4 05-27-2008 01:02 PM
