Mineral Guard Roll Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-05-2012, 08:16 AM   #1
toeey1's Avatar
First let me start by saying I realize this is an inferior product compared to other roofing membranes(liberty cap sheet for example), however Im in a situation that requires a low sloped roofing application and need a cheaper fix I just had a few questions in regards to the mineral guard(or other rolled roofing) product.
With regards to felt paper(#15 or #30) Ive heard you can use it underneath rolled roofing and then Ive also heard you cannot use it underneath it. Whats correct?
Also the henry rolled roofing adhesive 203 is specifically used to glue these products down but says do not use with #15 or #30 felt. So you just glue it directly to the decking?? Thanks for the tips.
toeey1 is offline   Reply With Quote
Old 06-05-2012, 08:43 AM   #2
Rewards Points: 13,712
It does not get glued down to the decking, it's for the over lapping seams.
Old 06-05-2012, 11:21 AM   #3
Low Slope Roofing
Rewards Points: 114
You would need to nail down a base sheet first, then install the roll roofing set in the adhesive.
1985gt is offline   Reply With Quote
Old 06-05-2012, 08:05 PM   #4
toeey1's Avatar
Would that be a felt or another type of base sheet?
Old 06-05-2012, 09:35 PM   #5
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Keep in mind the rolled roofing isn't made for low slope. Within weeks maybe, you'll probably be tearing it off to go with a base sheet and cap sheet of SBS. Take plenty of paint thinner to help clean up when you tear it back off. It's going to be real messy.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
OldNBroken (06-08-2012)
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
Vent Flashing for Low Slope Mineral Surface Roll Roofing Thumbhammer Roofing/Siding 4 05-22-2011 05:52 AM
Cold Ap Roll Roofing CarlosHRNYC Roofing/Siding 1 04-29-2011 06:50 AM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 05:32 PM
