Min Temp To Apply Torchdown And Peel And Stick Base Sheet ?? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-01-2008, 09:43 PM   #1
min temp to apply torchdown and peel and stick base sheet ??
what is the recommended min substrate temp to apply black diamond peel and stick base sheet, and bitec apm torch down cap sheet. Im in central fla, and the temp is going to be dipping down low these next few days, but would really like to get it done. my roofer is at odds with the material supplier, what do you'all reccomend ??thanks
diymichoacan is offline   Reply With Quote
Old 01-02-2008, 08:34 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
40 and rising for some brands. 45 and up for others.
Weird question coming from Fla.
tinner666 is offline   Reply With Quote
Old 01-02-2008, 09:51 PM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
the black diamond ,above freezing is ok,remember it`s gonna seal more agressively as you torchdown onto it with the finished roof,really good stuff
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 01-03-2008, 12:48 AM   #4
2 factors to be considered during colder applications.
Temperature with wind.
and
Are the rolls left in the sub-freezing or kept warm in the truck until needed.
An experienced torch roofing mechanic will be able to tell if the roll is too cold when rolling it out and it starts to spider-web crack while unravelling.
What are the "At Odds" points between your roofer and the supplier?
Ed
Ed the Roofer is offline   Reply With Quote
Old 01-03-2008, 09:04 AM   #5
he`s posting from florida Ed,lI don`t think it`s been at freezing temp yet,(there anyways??)
Old 01-03-2008, 10:01 AM   #6
I know, but I have been down there when it got down to 20*, which shouldn't be too cold, but I wanted to know what issues the roofer and the supplier were in disagreement about.
ed
